staging: media: omap1: Replace clk_get with devm_clk_get
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
devm_clk_get allocated resources get released when a driver detaches.
Replace clk_get with devm_clk_get and remove corresponding data
releasing function clk_put from probe and remove functions of a
platform device. Also remove an unnecessary label.
This change was made with the help of the following Coccinelle
semantic patch:
@platform@
identifier p, probefn, removefn;
struct platform_driver p = {
  .probe = probefn,
  .remove = removefn,
@prb@
identifier platform.probefn, pdev;
expression e;
probefn(struct platform_device *pdev, ...) {
  e =
- clk_get
+ devm_clk_get
?- clk_put(...);
@remove depends on prb@
identifier platform.removefn;
removefn(...) {
?- clk_put(...);
Signed-off-by: Amitoj Kaur Chawla
 drivers/staging/media/omap1/omap1_camera.c | 15 ++++-----------
 1 file changed, 4 insertions(+), 11 deletions(-)
diff --git a/drivers/staging/media/omap1/omap1_camera.c b/drivers/staging/media/omap1/omap1_camera.c
index bd721e3..bd00180 100644
--- a/drivers/staging/media/omap1/omap1_camera.c
+++ b/drivers/staging/media/omap1/omap1_camera.c
@@ -1576,17 +1576,14 @@ static int omap1_cam_probe(struct platform_device *pdev)
 		goto exit;
-	clk = clk_get(&pdev->dev, "armper_ck");
-	if (IS_ERR(clk)) {
-		err = PTR_ERR(clk);
-		goto exit;
+	clk = devm_clk_get(&pdev->dev, "armper_ck");
+	if (IS_ERR(clk))
+		return PTR_ERR(clk);
 	pcdev = kzalloc(sizeof(*pcdev) + resource_size(res), GFP_KERNEL);
 	if (!pcdev) {
 		dev_err(&pdev->dev, "Could not allocate pcdev\n");
-		err = -ENOMEM;
-		goto exit_put_clk;
+		return -ENOMEM;
 	pcdev->res = res;
@@ -1685,8 +1682,6 @@ exit_release:
 	release_mem_region(res->start, resource_size(res));
 exit_kfree:
 	kfree(pcdev);
-exit_put_clk:
-	clk_put(clk);
 exit:
 	return err;
@@ -1709,8 +1704,6 @@ static int omap1_cam_remove(struct platform_device *pdev)
 	res = pcdev->res;
-	clk_put(pcdev->clk);
 	kfree(pcdev);
 	dev_info(&pdev->dev, "OMAP1 Camera Interface driver unloaded\n");
BtrLinux
Privacy Overview
