Orangefs: fix ifnullfree.cocci warnings
Author: kbuild test robot <fengguang.wu@intel.com>
fs/orangefs/orangefs-debugfs.c:130:2-26: WARNING: NULL check before freeing functions like kfree, debugfs_remove, debugfs_remove_recursive or usb_free_urb is not needed. Maybe consider reorganizing relevant code to avoid passing NULL values.
 NULL check before some freeing functions is not needed.
 Based on checkpatch warning
 "kfree(NULL) is safe this check is probably not required"
 and kfreeaddr.cocci by Julia Lawall.
Generated by: scripts/coccinelle/free/ifnullfree.cocci
Signed-off-by: Fengguang Wu
Signed-off-by: Mike Marshall
 fs/orangefs/orangefs-debugfs.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/fs/orangefs/orangefs-debugfs.c b/fs/orangefs/orangefs-debugfs.c
index 19670b8..1714a73 100644
--- a/fs/orangefs/orangefs-debugfs.c
+++ b/fs/orangefs/orangefs-debugfs.c
@@ -126,8 +126,7 @@ out:
 void orangefs_debugfs_cleanup(void)
-	if (debug_dir)
-		debugfs_remove_recursive(debug_dir);
+	debugfs_remove_recursive(debug_dir);
 /* open ORANGEFS_KMOD_DEBUG_HELP_FILE */
BtrLinux
Privacy Overview
