drivers: net: xgene: constify xgene_cle_ops structure
Author: Julia Lawall <julia.lawall@lip6.fr>
The xgene_cle_ops structure is never modified, so declare it as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall
Acked-by: Iyappan Subramanian
 drivers/net/ethernet/apm/xgene/xgene_enet_cle.c  | 2 +-
 drivers/net/ethernet/apm/xgene/xgene_enet_cle.h  | 2 +-
 drivers/net/ethernet/apm/xgene/xgene_enet_main.h | 2 +-
 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/ethernet/apm/xgene/xgene_enet_cle.c b/drivers/net/ethernet/apm/xgene/xgene_enet_cle.c
index b2124886..6479288 100644
--- a/drivers/net/ethernet/apm/xgene/xgene_enet_cle.c
+++ b/drivers/net/ethernet/apm/xgene/xgene_enet_cle.c
@@ -729,6 +729,6 @@ static int xgene_enet_cle_init(struct xgene_enet_pdata *pdata)
 	return xgene_cle_setup_ptree(pdata, enet_cle);
-struct xgene_cle_ops xgene_cle3in_ops = {
+const struct xgene_cle_ops xgene_cle3in_ops = {
 	.cle_init = xgene_enet_cle_init,
diff --git a/drivers/net/ethernet/apm/xgene/xgene_enet_cle.h b/drivers/net/ethernet/apm/xgene/xgene_enet_cle.h
index 29a17ab..13e829a 100644
--- a/drivers/net/ethernet/apm/xgene/xgene_enet_cle.h
+++ b/drivers/net/ethernet/apm/xgene/xgene_enet_cle.h
@@ -290,6 +290,6 @@ struct xgene_enet_cle {
 	u32 jump_bytes;
-extern struct xgene_cle_ops xgene_cle3in_ops;
+extern const struct xgene_cle_ops xgene_cle3in_ops;
 #endif /* __XGENE_ENET_CLE_H__ */
diff --git a/drivers/net/ethernet/apm/xgene/xgene_enet_main.h b/drivers/net/ethernet/apm/xgene/xgene_enet_main.h
index 175d188..0a2887b 100644
--- a/drivers/net/ethernet/apm/xgene/xgene_enet_main.h
+++ b/drivers/net/ethernet/apm/xgene/xgene_enet_main.h
@@ -191,7 +191,7 @@ struct xgene_enet_pdata {
 	const struct xgene_mac_ops *mac_ops;
 	const struct xgene_port_ops *port_ops;
 	struct xgene_ring_ops *ring_ops;
-	struct xgene_cle_ops *cle_ops;
+	const struct xgene_cle_ops *cle_ops;
 	struct delayed_work link_work;
 	u32 port_id;
 	u8 cpu_bufnum; |
 	u32 jump_bytes;
 	u32 port_id;
 	u8 cpu_bufnum;
