USB: mon_stat.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
Reviewed-by: Felipe Balbi
drivers/usb/mon/mon_stat.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/usb/mon/mon_stat.c b/drivers/usb/mon/mon_stat.c
index ebd6189..5388a33 100644
--- a/drivers/usb/mon/mon_stat.c
+++ b/drivers/usb/mon/mon_stat.c
@@ -28,7 +28,8 @@ static int mon_stat_open(struct inode *inode, struct file *file)
struct mon_bus *mbus;
struct snap *sp;
- if ((sp = kmalloc(sizeof(struct snap), GFP_KERNEL)) == NULL)
+ sp = kmalloc(sizeof(struct snap), GFP_KERNEL);
+ if (sp == NULL)
return -ENOMEM;
mbus = inode->i_private; |
struct snap *sp;
+ if (sp == NULL)
return -ENOMEM;
