drivers/gpu/drm/i915/i915_dma.c | 22 +++----
drivers/gpu/drm/i915/i915_gem.c | 2 +-
drivers/gpu/drm/i915/i915_gpu_error.c | 6 +-
drivers/gpu/drm/i915/i915_irq.c | 8 +--
drivers/gpu/drm/i915/intel_ringbuffer.c | 102 ++++++++++++++++----------------
drivers/gpu/drm/i915/intel_ringbuffer.h | 27 ++-------
6 files changed, 75 insertions(+), 92 deletions(-)
diff --git a/drivers/gpu/drm/i915/i915_dma.c b/drivers/gpu/drm/i915/i915_dma.c
index 13784fe..234d454 100644
--- a/drivers/gpu/drm/i915/i915_dma.c
+++ b/drivers/gpu/drm/i915/i915_dma.c
@@ -64,7 +64,7 @@
* has access to the ring.
#define RING_LOCK_TEST_WITH_RETURN(dev, file) do { \
- if (LP_RING(dev->dev_private)->obj == NULL) \
+ if (LP_RING(dev->dev_private)->buffer->obj == NULL) \
LOCK_TEST_WITH_RETURN(dev, file); \
} while (0)
@@ -149,17 +149,17 @@ void i915_kernel_lost_context(struct drm_device * dev)
if (drm_core_check_feature(dev, DRIVER_MODESET))
return;
- ring->head = I915_READ_HEAD(ring) & HEAD_ADDR;
- ring->tail = I915_READ_TAIL(ring) & TAIL_ADDR;
- ring->space = ring->head - (ring->tail + I915_RING_FREE_SPACE);
- if (ring->space < 0)
- ring->space += ring->size;
+ ring->buffer->head = I915_READ_HEAD(ring) & HEAD_ADDR;
+ ring->buffer->tail = I915_READ_TAIL(ring) & TAIL_ADDR;
+ ring->buffer->space = ring->buffer->head - (ring->buffer->tail + I915_RING_FREE_SPACE);
+ if (ring->buffer->space < 0)
+ ring->buffer->space += ring->buffer->size;
if (!dev->primary->master)
return;
master_priv = dev->primary->master->driver_priv;
- if (ring->head == ring->tail && master_priv->sarea_priv)
+ if (ring->buffer->head == ring->buffer->tail && master_priv->sarea_priv)
master_priv->sarea_priv->perf_boxes |= I915_BOX_RING_EMPTY;
@@ -202,7 +202,7 @@ static int i915_initialize(struct drm_device * dev, drm_i915_init_t * init)
if (init->ring_size != 0) {
- if (LP_RING(dev_priv)->obj != NULL) {
+ if (LP_RING(dev_priv)->buffer->obj != NULL) {
i915_dma_cleanup(dev);
DRM_ERROR("Client tried to initialize ringbuffer in "
"GEM mode\n");
@@ -239,7 +239,7 @@ static int i915_dma_resume(struct drm_device * dev)
DRM_DEBUG_DRIVER("%s\n", __func__);
- if (ring->virtual_start == NULL) {
+ if (ring->buffer->virtual_start == NULL) {
DRM_ERROR("can not ioremap virtual address for"
" ring buffer\n");
return -ENOMEM;
@@ -361,7 +361,7 @@ static int i915_emit_cmds(struct drm_device * dev, int *buffer, int dwords)
struct drm_i915_private *dev_priv = dev->dev_private;
int i, ret;
- if ((dwords+1) * sizeof(int) >= LP_RING(dev_priv)->size - 8)
+ if ((dwords+1) * sizeof(int) >= LP_RING(dev_priv)->buffer->size - 8)
return -EINVAL;
for (i = 0; i < dwords;) {
@@ -824,7 +824,7 @@ static int i915_irq_emit(struct drm_device *dev, void *data,
return -ENODEV;
- if (!dev_priv || !LP_RING(dev_priv)->virtual_start) {
+ if (!dev_priv || !LP_RING(dev_priv)->buffer->virtual_start) {
DRM_ERROR("called with no initialization\n");
return -EINVAL;
diff --git a/drivers/gpu/drm/i915/i915_gem.c b/drivers/gpu/drm/i915/i915_gem.c
index 382eae7..db7796b 100644
--- a/drivers/gpu/drm/i915/i915_gem.c
+++ b/drivers/gpu/drm/i915/i915_gem.c
@@ -2523,7 +2523,7 @@ i915_gem_retire_requests_ring(struct intel_engine_cs *ring)
* of tail of the request to update the last known position
* of the GPU head.
- ring->last_retired_head = request->tail;
+ ring->buffer->last_retired_head = request->tail;
i915_gem_free_request(request);
diff --git a/drivers/gpu/drm/i915/i915_gpu_error.c b/drivers/gpu/drm/i915/i915_gpu_error.c
index 632db42..87ec60e 100644
--- a/drivers/gpu/drm/i915/i915_gpu_error.c
+++ b/drivers/gpu/drm/i915/i915_gpu_error.c
@@ -825,8 +825,8 @@ static void i915_record_ring_state(struct drm_device *dev,
ering->hws = I915_READ(mmio);
- ering->cpu_ring_head = ring->head;
- ering->cpu_ring_tail = ring->tail;
+ ering->cpu_ring_head = ring->buffer->head;
+ ering->cpu_ring_tail = ring->buffer->tail;
ering->hangcheck_score = ring->hangcheck.score;
ering->hangcheck_action = ring->hangcheck.action;
@@ -930,7 +930,7 @@ static void i915_gem_record_rings(struct drm_device *dev,
error->ring[i].ringbuffer =
- i915_error_ggtt_object_create(dev_priv, ring->obj);
+ i915_error_ggtt_object_create(dev_priv, ring->buffer->obj);
if (ring->status_page.obj)
error->ring[i].hws_page =
diff --git a/drivers/gpu/drm/i915/i915_irq.c b/drivers/gpu/drm/i915/i915_irq.c
index c28e0da..152ba12 100644
--- a/drivers/gpu/drm/i915/i915_irq.c
+++ b/drivers/gpu/drm/i915/i915_irq.c
@@ -1219,7 +1219,7 @@ static void ironlake_rps_change_irq_handler(struct drm_device *dev)
static void notify_ring(struct drm_device *dev,
- if (ring->obj == NULL)
+ if (ring->buffer->obj == NULL)
return;
trace_i915_gem_request_complete(ring);
@@ -2837,10 +2837,10 @@ semaphore_waits_for(struct intel_engine_cs *ring, u32 *seqno)
* our ring is smaller than what the hardware (and hence
* HEAD_ADDR) allows. Also handles wrap-around.
- head &= ring->size - 1;
+ head &= ring->buffer->size - 1;
/* This here seems to blow up */
- cmd = ioread32(ring->virtual_start + head);
+ cmd = ioread32(ring->buffer->virtual_start + head);
if (cmd == ipehr)
break;
@@ -2850,7 +2850,7 @@ semaphore_waits_for(struct intel_engine_cs *ring, u32 *seqno)
if (!i)
return NULL;
- *seqno = ioread32(ring->virtual_start + head + 4) + 1;
+ *seqno = ioread32(ring->buffer->virtual_start + head + 4) + 1;
return semaphore_wait_to_signaller_ring(ring, ipehr);
diff --git a/drivers/gpu/drm/i915/intel_ringbuffer.c b/drivers/gpu/drm/i915/intel_ringbuffer.c
index 9b406e42..70f1b88 100644
--- a/drivers/gpu/drm/i915/intel_ringbuffer.c
+++ b/drivers/gpu/drm/i915/intel_ringbuffer.c
@@ -50,7 +50,7 @@ static inline int __ring_space(int head, int tail, int size)
static inline int ring_space(struct intel_engine_cs *ring)
- return __ring_space(ring->head & HEAD_ADDR, ring->tail, ring->size);
+ return __ring_space(ring->buffer->head & HEAD_ADDR, ring->buffer->tail, ring->buffer->size);
static bool intel_ring_stopped(struct intel_engine_cs *ring)
@@ -61,10 +61,10 @@ static bool intel_ring_stopped(struct intel_engine_cs *ring)
void __intel_ring_advance(struct intel_engine_cs *ring)
- ring->tail &= ring->size - 1;
+ ring->buffer->tail &= ring->buffer->size - 1;
if (intel_ring_stopped(ring))
return;
- ring->write_tail(ring, ring->tail);
+ ring->write_tail(ring, ring->buffer->tail);
static int
@@ -481,7 +481,7 @@ static int init_ring_common(struct intel_engine_cs *ring)
struct drm_device *dev = ring->dev;
- struct drm_i915_gem_object *obj = ring->obj;
+ struct drm_i915_gem_object *obj = ring->buffer->obj;
int ret = 0;
gen6_gt_force_wake_get(dev_priv, FORCEWAKE_ALL);
@@ -520,7 +520,7 @@ static int init_ring_common(struct intel_engine_cs *ring)
* register values. */
I915_WRITE_START(ring, i915_gem_obj_ggtt_offset(obj));
I915_WRITE_CTL(ring,
- ((ring->size - PAGE_SIZE) & RING_NR_PAGES)
+ ((ring->buffer->size - PAGE_SIZE) & RING_NR_PAGES)
| RING_VALID);
/* If the head is still not zero, the ring is dead */
@@ -540,10 +540,10 @@ static int init_ring_common(struct intel_engine_cs *ring)
if (!drm_core_check_feature(ring->dev, DRIVER_MODESET))
i915_kernel_lost_context(ring->dev);
else {
- ring->head = I915_READ_HEAD(ring);
- ring->space = ring_space(ring);
- ring->last_retired_head = -1;
+ ring->buffer->head = I915_READ_HEAD(ring);
+ ring->buffer->space = ring_space(ring);
+ ring->buffer->last_retired_head = -1;
memset(&ring->hangcheck, 0, sizeof(ring->hangcheck));
@@ -1382,14 +1382,14 @@ static int allocate_ring_buffer(struct intel_engine_cs *ring)
struct drm_i915_gem_object *obj;
int ret;
- if (ring->obj)
+ if (ring->buffer->obj)
return 0;
obj = NULL;
if (!HAS_LLC(dev))
- obj = i915_gem_object_create_stolen(dev, ring->size);
+ obj = i915_gem_object_create_stolen(dev, ring->buffer->size);
if (obj == NULL)
- obj = i915_gem_alloc_object(dev, ring->size);
+ obj = i915_gem_alloc_object(dev, ring->buffer->size);
if (obj == NULL)
return -ENOMEM;
@@ -1401,15 +1401,15 @@ static int allocate_ring_buffer(struct intel_engine_cs *ring)
if (ret)
goto err_unpin;
- ring->virtual_start =
+ ring->buffer->virtual_start =
ioremap_wc(dev_priv->gtt.mappable_base + i915_gem_obj_ggtt_offset(obj),
- ring->size);
+ ring->buffer->size);
ret = -EINVAL;
goto err_unpin;
- ring->obj = obj;
+ ring->buffer->obj = obj;
return 0;
err_unpin:
@@ -1435,7 +1435,7 @@ static int intel_init_ring_buffer(struct drm_device *dev,
ring->dev = dev;
INIT_LIST_HEAD(&ring->active_list);
INIT_LIST_HEAD(&ring->request_list);
- ring->size = 32 * PAGE_SIZE;
+ ring->buffer->size = 32 * PAGE_SIZE;
memset(ring->semaphore.sync_seqno, 0, sizeof(ring->semaphore.sync_seqno));
init_waitqueue_head(&ring->irq_queue);
@@ -1461,9 +1461,9 @@ static int intel_init_ring_buffer(struct drm_device *dev,
* the TAIL pointer points to within the last 2 cachelines
* of the buffer.
- ring->effective_size = ring->size;
+ ring->buffer->effective_size = ring->buffer->size;
if (IS_I830(dev) || IS_845G(dev))
- ring->effective_size -= 2 * CACHELINE_BYTES;
+ ring->buffer->effective_size -= 2 * CACHELINE_BYTES;
ret = i915_cmd_parser_init_ring(ring);
if (ret)
@@ -1485,17 +1485,17 @@ void intel_cleanup_ring_buffer(struct intel_engine_cs *ring)
struct drm_i915_private *dev_priv = to_i915(ring->dev);
return;
intel_stop_ring_buffer(ring);
WARN_ON((I915_READ_MODE(ring) & MODE_IDLE) == 0);
- iounmap(ring->virtual_start);
+ iounmap(ring->buffer->virtual_start);
- i915_gem_object_ggtt_unpin(ring->obj);
- drm_gem_object_unreference(&ring->obj->base);
- ring->obj = NULL;
+ i915_gem_object_ggtt_unpin(ring->buffer->obj);
+ drm_gem_object_unreference(&ring->buffer->obj->base);
+ ring->buffer->obj = NULL;
ring->preallocated_lazy_request = NULL;
ring->outstanding_lazy_seqno = 0;
@@ -1516,17 +1516,17 @@ static int intel_ring_wait_request(struct intel_engine_cs *ring, int n)
u32 seqno = 0;
int ret;
- if (ring->last_retired_head != -1) {
- ring->head = ring->last_retired_head;
+ if (ring->buffer->last_retired_head != -1) {
+ ring->buffer->head = ring->buffer->last_retired_head;
- if (ring->space >= n)
+ if (ring->buffer->space >= n)
return 0;
list_for_each_entry(request, &ring->request_list, list) {
- if (__ring_space(request->tail, ring->tail, ring->size) >= n) {
+ if (__ring_space(request->tail, ring->buffer->tail, ring->buffer->size) >= n) {
seqno = request->seqno;
break;
@@ -1540,10 +1540,10 @@ static int intel_ring_wait_request(struct intel_engine_cs *ring, int n)
return ret;
i915_gem_retire_requests_ring(ring);
return 0;
@@ -1570,9 +1570,9 @@ static int ring_wait_for_space(struct intel_engine_cs *ring, int n)
trace_i915_ring_wait_begin(ring);
do {
- if (ring->space >= n) {
+ if (ring->buffer->space >= n) {
ret = 0;
break;
@@ -1608,21 +1608,21 @@ static int ring_wait_for_space(struct intel_engine_cs *ring, int n)
static int intel_wrap_ring_buffer(struct intel_engine_cs *ring)
uint32_t __iomem *virt;
- int rem = ring->size - ring->tail;
+ int rem = ring->buffer->size - ring->buffer->tail;
- if (ring->space < rem) {
+ if (ring->buffer->space < rem) {
int ret = ring_wait_for_space(ring, rem);
if (ret)
return ret;
- virt = ring->virtual_start + ring->tail;
+ virt = ring->buffer->virtual_start + ring->buffer->tail;
rem /= 4;
while (rem--)
iowrite32(MI_NOOP, virt++);
- ring->tail = 0;
+ ring->buffer->tail = 0;
return 0;
@@ -1674,13 +1674,13 @@ static int __intel_ring_prepare(struct intel_engine_cs *ring,
int ret;
- if (unlikely(ring->tail + bytes > ring->effective_size)) {
+ if (unlikely(ring->buffer->tail + bytes > ring->buffer->effective_size)) {
ret = intel_wrap_ring_buffer(ring);
if (unlikely(ret))
return ret;
- if (unlikely(ring->space < bytes)) {
+ if (unlikely(ring->buffer->space < bytes)) {
ret = ring_wait_for_space(ring, bytes);
if (unlikely(ret))
return ret;
@@ -1709,14 +1709,14 @@ int intel_ring_begin(struct intel_engine_cs *ring,
if (ret)
return ret;
- ring->space -= num_dwords * sizeof(uint32_t);
+ ring->buffer->space -= num_dwords * sizeof(uint32_t);
return 0;
/* Align the ring tail to a cacheline boundary */
int intel_ring_cacheline_align(struct intel_engine_cs *ring)
- int num_dwords = (ring->tail & (CACHELINE_BYTES - 1)) / sizeof(uint32_t);
+ int num_dwords = (ring->buffer->tail & (CACHELINE_BYTES - 1)) / sizeof(uint32_t);
int ret;
if (num_dwords == 0)
@@ -2094,13 +2094,13 @@ int intel_render_ring_init_dri(struct drm_device *dev, u64 start, u32 size)
- ring->size = size;
+ ring->buffer->size = size;
if (IS_I830(ring->dev) || IS_845G(ring->dev))
- ring->virtual_start = ioremap_wc(start, size);
+ ring->buffer->virtual_start = ioremap_wc(start, size);
" ring buffer\n");
ret = -ENOMEM;
@@ -2116,7 +2116,7 @@ int intel_render_ring_init_dri(struct drm_device *dev, u64 start, u32 size)
return 0;
err_vstart:
err_ringbuf:
kfree(ringbuf);
ring->buffer = NULL;
diff --git a/drivers/gpu/drm/i915/intel_ringbuffer.h b/drivers/gpu/drm/i915/intel_ringbuffer.h
index a0ac668..c26def08 100644
--- a/drivers/gpu/drm/i915/intel_ringbuffer.h
+++ b/drivers/gpu/drm/i915/intel_ringbuffer.h
@@ -91,28 +91,11 @@ struct intel_engine_cs {
#define I915_NUM_RINGS 5
#define LAST_USER_RING (VECS + 1)
u32 mmio_base;
- void __iomem *virtual_start;
struct drm_device *dev;
- struct drm_i915_gem_object *obj;
struct intel_ringbuffer *buffer;
- u32 head;
- u32 tail;
- int space;
- int size;
- int effective_size;
struct intel_hw_status_page status_page;
- /** We track the position of the requests in the ring buffer, and
- * when each is retired we increment last_retired_head as the GPU
- * must have finished processing the request and so we know we
- * can advance the ringbuffer up to that position.
- * last_retired_head is set to -1 after the value is consumed so
- * we can detect new retirements.
- u32 last_retired_head;
unsigned irq_refcount; /* protected by dev_priv->irq_lock */
u32 irq_enable_mask; /* bitmask to enable ring interrupt */
u32 trace_irq_seqno;
@@ -239,7 +222,7 @@ struct intel_engine_cs {
static inline bool
intel_ring_initialized(struct intel_engine_cs *ring)
- return ring->buffer && ring->obj;
+ return ring->buffer && ring->buffer->obj;
static inline unsigned
@@ -310,12 +293,12 @@ int __must_check intel_ring_cacheline_align(struct intel_engine_cs *ring);
static inline void intel_ring_emit(struct intel_engine_cs *ring,
u32 data)
- iowrite32(data, ring->virtual_start + ring->tail);
- ring->tail += 4;
+ iowrite32(data, ring->buffer->virtual_start + ring->buffer->tail);
+ ring->buffer->tail += 4;
static inline void intel_ring_advance(struct intel_engine_cs *ring)
void __intel_ring_advance(struct intel_engine_cs *ring);
@@ -335,7 +318,7 @@ void intel_ring_setup_status_page(struct intel_engine_cs *ring);
static inline u32 intel_ring_get_tail(struct intel_engine_cs *ring)
- return ring->tail;
+ return ring->buffer->tail;
static inline u32 intel_ring_get_seqno(struct intel_engine_cs *ring) |
