zorro: Use ARRAY_SIZE
Author: Himangi Saraogi <himangi774@gmail.com>
ARRAY_SIZE is more concise to use when the size of an array is divided
by the size of its type or the size of its first element.
The Coccinelle semantic patch that makes this change is as follows:
type T;
T[] E;
- (sizeof(E)/sizeof(T))
+ ARRAY_SIZE(E)
Signed-off-by: Himangi Saraogi
[Geert: Also convert the MANUF definition]
Signed-off-by: Geert Uytterhoeven
 drivers/zorro/names.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/zorro/names.c b/drivers/zorro/names.c
index 6f3fd99..83eeddd 100644
--- a/drivers/zorro/names.c
+++ b/drivers/zorro/names.c
@@ -46,13 +46,13 @@ struct zorro_manuf_info {
 #include "devlist.h"
 static struct zorro_manuf_info __initdata zorro_manuf_list[] = {
-#define MANUF( manuf, name )		{ 0x##manuf, sizeof(__prods_##manuf) / sizeof(struct zorro_prod_info), __manufstr_##manuf, __prods_##manuf },
+#define MANUF( manuf, name )		{ 0x##manuf, ARRAY_SIZE(__prods_##manuf), __manufstr_##manuf, __prods_##manuf },
 #define ENDMANUF()
 #define PRODUCT( manuf, prod, name )
-#define MANUFS (sizeof(zorro_manuf_list)/sizeof(struct zorro_manuf_info))
+#define MANUFS ARRAY_SIZE(zorro_manuf_list)
 void __init zorro_name_device(struct zorro_dev *dev)
BtrLinux
Privacy Overview
