drivers/net/ethernet/xircom/xirc2ps_cs.c | 40 ++++++++++++++++----------------
1 file changed, 20 insertions(+), 20 deletions(-)
diff --git a/drivers/net/ethernet/xircom/xirc2ps_cs.c b/drivers/net/ethernet/xircom/xirc2ps_cs.c
index 7c81ffb..d56f869 100644
--- a/drivers/net/ethernet/xircom/xirc2ps_cs.c
+++ b/drivers/net/ethernet/xircom/xirc2ps_cs.c
@@ -266,7 +266,7 @@ static void xirc2ps_detach(struct pcmcia_device *p_dev);
static irqreturn_t xirc2ps_interrupt(int irq, void *dev_id);
-typedef struct local_info_t {
+struct local_info {
struct net_device *dev;
struct pcmcia_device *p_dev;
@@ -281,7 +281,7 @@ typedef struct local_info_t {
unsigned last_ptr_value; /* last packets transmitted value */
const char *manf_str;
struct work_struct tx_timeout_task;
-} local_info_t;
* Some more prototypes
@@ -475,12 +475,12 @@ static int
xirc2ps_probe(struct pcmcia_device *link)
- local_info_t *local;
+ struct local_info *local;
dev_dbg(&link->dev, "attach()\n");
/* Allocate the device structure */
- dev = alloc_etherdev(sizeof(local_info_t));
+ dev = alloc_etherdev(sizeof(struct local_info));
if (!dev)
return -ENOMEM;
local = netdev_priv(dev);
@@ -536,7 +536,7 @@ static int
set_card_type(struct pcmcia_device *link)
struct net_device *dev = link->priv;
- local_info_t *local = netdev_priv(dev);
+ struct local_info *local = netdev_priv(dev);
u8 *buf;
unsigned int cisrev, mediaid, prodid;
size_t len;
@@ -690,7 +690,7 @@ static int
xirc2ps_config(struct pcmcia_device * link)
unsigned int ioaddr;
int err;
u8 *buf;
@@ -931,7 +931,7 @@ xirc2ps_release(struct pcmcia_device *link)
if (link->resource[2]->end) {
if (local->dingo)
iounmap(local->dingo_ccr - 0x0800);
@@ -975,7 +975,7 @@ static irqreturn_t
struct net_device *dev = (struct net_device *)dev_id;
- local_info_t *lp = netdev_priv(dev);
+ struct local_info *lp = netdev_priv(dev);
u_char saved_page;
unsigned bytes_rcvd;
@@ -1194,8 +1194,8 @@ xirc2ps_interrupt(int irq, void *dev_id)
static void
xirc2ps_tx_timeout_task(struct work_struct *work)
- container_of(work, local_info_t, tx_timeout_task);
+ container_of(work, struct local_info, tx_timeout_task);
struct net_device *dev = local->dev;
/* reset the card */
do_reset(dev,1);
@@ -1206,7 +1206,7 @@ xirc2ps_tx_timeout_task(struct work_struct *work)
static void
xirc_tx_timeout(struct net_device *dev)
dev->stats.tx_errors++;
netdev_notice(dev, "transmit timed out\n");
schedule_work(&lp->tx_timeout_task);
@@ -1215,7 +1215,7 @@ xirc_tx_timeout(struct net_device *dev)
static netdev_tx_t
do_start_xmit(struct sk_buff *skb, struct net_device *dev)
unsigned int ioaddr = dev->base_addr;
int okay;
unsigned freespace;
@@ -1300,7 +1300,7 @@ static void set_address(struct set_address_info *sa_info, char *addr)
static void set_addresses(struct net_device *dev)
struct netdev_hw_addr *ha;
struct set_address_info sa_info;
int i;
@@ -1362,7 +1362,7 @@ set_multicast_list(struct net_device *dev)
static int
do_config(struct net_device *dev, struct ifmap *map)
pr_debug("do_config(%p)\n", dev);
if (map->port != 255 && map->port != dev->if_port) {
@@ -1387,7 +1387,7 @@ do_config(struct net_device *dev, struct ifmap *map)
static int
do_open(struct net_device *dev)
struct pcmcia_device *link = lp->p_dev;
dev_dbg(&link->dev, "do_open(%p)\n", dev);
@@ -1421,7 +1421,7 @@ static const struct ethtool_ops netdev_ethtool_ops = {
static int
do_ioctl(struct net_device *dev, struct ifreq *rq, int cmd)
struct mii_ioctl_data *data = if_mii(rq);
@@ -1453,7 +1453,7 @@ do_ioctl(struct net_device *dev, struct ifreq *rq, int cmd)
static void
hardreset(struct net_device *dev)
SelectPage(4);
@@ -1470,7 +1470,7 @@ hardreset(struct net_device *dev)
static void
do_reset(struct net_device *dev, int full)
unsigned value;
@@ -1631,7 +1631,7 @@ do_reset(struct net_device *dev, int full)
static int
init_mii(struct net_device *dev)
unsigned control, status, linkpartner;
int i;
@@ -1715,7 +1715,7 @@ static int
do_stop(struct net_device *dev)
dev_dbg(&link->dev, "do_stop(%p)\n", dev); |
