Bluetooth: Remove typedef btuart_info_t
Author: Himangi Saraogi <himangi774@gmail.com>
The Linux kernel coding style guidelines suggest not using typedefs
for structure types. This patch gets rid of the typedef for
btuart_info_t. Also, the name of the struct is changed to drop the _t,
to make the name look less typedef-like.
The following Coccinelle semantic patch detects the case:
@tn@
identifier i;
type td;
-typedef
 struct i { ... }
-td
type tn.td;
identifier tn.i;
-td
+ struct i
Signed-off-by: Himangi Saraogi
Acked-by: Julia Lawall
Signed-off-by: Marcel Holtmann
 drivers/bluetooth/btuart_cs.c | 27 ++++++++++++++-------------
 1 file changed, 14 insertions(+), 13 deletions(-)
diff --git a/drivers/bluetooth/btuart_cs.c b/drivers/bluetooth/btuart_cs.c
index fb948f0..abb4d21 100644
--- a/drivers/bluetooth/btuart_cs.c
+++ b/drivers/bluetooth/btuart_cs.c
@@ -62,7 +62,7 @@ MODULE_LICENSE("GPL");
 /* ======================== Local structures ======================== */
-typedef struct btuart_info_t {
+struct btuart_info {
 	struct pcmcia_device *p_dev;
 	struct hci_dev *hdev;
@@ -75,7 +75,7 @@ typedef struct btuart_info_t {
 	unsigned long rx_state;
 	unsigned long rx_count;
 	struct sk_buff *rx_skb;
-} btuart_info_t;
 static int btuart_config(struct pcmcia_device *link);
@@ -127,7 +127,7 @@ static int btuart_write(unsigned int iobase, int fifo_size, __u8 *buf, int len)
-static void btuart_write_wakeup(btuart_info_t *info)
+static void btuart_write_wakeup(struct btuart_info *info)
 	if (!info) {
 		BT_ERR("Unknown device");
@@ -172,7 +172,7 @@ static void btuart_write_wakeup(btuart_info_t *info)
-static void btuart_receive(btuart_info_t *info)
+static void btuart_receive(struct btuart_info *info)
 	unsigned int iobase;
 	int boguscount = 0;
@@ -286,7 +286,7 @@ static void btuart_receive(btuart_info_t *info)
 static irqreturn_t btuart_interrupt(int irq, void *dev_inst)
-	btuart_info_t *info = dev_inst;
+	struct btuart_info *info = dev_inst;
 	int boguscount = 0;
 	int iir, lsr;
@@ -340,7 +340,8 @@ static irqreturn_t btuart_interrupt(int irq, void *dev_inst)
-static void btuart_change_speed(btuart_info_t *info, unsigned int speed)
+static void btuart_change_speed(struct btuart_info *info,
+				unsigned int speed)
 	unsigned long flags;
@@ -397,7 +398,7 @@ static void btuart_change_speed(btuart_info_t *info, unsigned int speed)
 static int btuart_hci_flush(struct hci_dev *hdev)
-	btuart_info_t *info = hci_get_drvdata(hdev);
+	struct btuart_info *info = hci_get_drvdata(hdev);
 	/* Drop TX queue */
 	skb_queue_purge(&(info->txq));
@@ -427,7 +428,7 @@ static int btuart_hci_close(struct hci_dev *hdev)
 static int btuart_hci_send_frame(struct hci_dev *hdev, struct sk_buff *skb)
 	switch (bt_cb(skb)->pkt_type) {
 	case HCI_COMMAND_PKT:
@@ -455,7 +456,7 @@ static int btuart_hci_send_frame(struct hci_dev *hdev, struct sk_buff *skb)
 /* ======================== Card services HCI interaction ======================== */
-static int btuart_open(btuart_info_t *info)
+static int btuart_open(struct btuart_info *info)
 	unsigned int iobase = info->p_dev->resource[0]->start;
@@ -521,7 +522,7 @@ static int btuart_open(btuart_info_t *info)
-static int btuart_close(btuart_info_t *info)
+static int btuart_close(struct btuart_info *info)
@@ -550,7 +551,7 @@ static int btuart_close(btuart_info_t *info)
 static int btuart_probe(struct pcmcia_device *link)
-	btuart_info_t *info;
+	struct btuart_info *info;
 	/* Create new info device */
 	info = devm_kzalloc(&link->dev, sizeof(*info), GFP_KERNEL);
@@ -613,7 +614,7 @@ static int btuart_check_config_notpicky(struct pcmcia_device *p_dev,
-	btuart_info_t *info = link->priv;
+	struct btuart_info *info = link->priv;
 	int i;
 	int try;
@@ -654,7 +655,7 @@ failed:
 static void btuart_release(struct pcmcia_device *link)
 	btuart_close(info);
BtrLinux
Privacy Overview
