staging: rtl8712: rewrite the right hand side of an assignment
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch rewrites the right hand side of an assignment for
expressions of the form:
a = (a b);
to be:
a = b;
where = << | >>.
This issue was detected and resolved using the following
coccinelle script:
identifier i;
expression e;
-i = (i >> e);
+i >>= e;
identifier i;
expression e;
-i = (i << e);
+i <<= e;
Signed-off-by: Aya Mahfouz
drivers/staging/rtl8712/rtl8712_recv.c | 10 +++++-----
1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/rtl8712/rtl8712_recv.c b/drivers/staging/rtl8712/rtl8712_recv.c
index cd8b444..e4fc9e0 100644
--- a/drivers/staging/rtl8712/rtl8712_recv.c
+++ b/drivers/staging/rtl8712/rtl8712_recv.c
@@ -161,7 +161,7 @@ static void update_recvframe_attrib_from_recvstat(struct rx_pkt_attrib *pattrib,
u16 drvinfo_sz = 0;
drvinfo_sz = (le32_to_cpu(prxstat->rxdw0)&0x000f0000)>>16;
- drvinfo_sz = drvinfo_sz<<3;
+ drvinfo_sz <<= 3;
/*TODO:
* Offset 0 */
pattrib->bdecrypted = ((le32_to_cpu(prxstat->rxdw0) & BIT(27)) >> 27)
@@ -436,7 +436,7 @@ void r8712_rxcmd_event_hdl(struct _adapter *padapter, void *prxcmdbuf)
voffset = *(uint *)poffset;
prxstat = (struct recv_stat *)prxcmdbuf;
drvinfo_sz = ((le32_to_cpu(prxstat->rxdw0) & 0x000f0000) >> 16);
- drvinfo_sz = drvinfo_sz << 3;
+ drvinfo_sz <<= 3;
poffset += RXDESC_SIZE + drvinfo_sz;
do {
@@ -749,7 +749,7 @@ static void query_rx_phy_status(struct _adapter *padapter,
if (!cck_highpwr) {
report = pcck_buf->cck_agc_rpt & 0xc0;
- report = report >> 6;
+ report >>= 6;
switch (report) {
/* Modify the RF RNA gain value to -40, -20,
* -2, 14 by Jenyu's suggestion
@@ -775,7 +775,7 @@ static void query_rx_phy_status(struct _adapter *padapter,
} else {
report = ((u8)(le32_to_cpu(pphy_stat->phydw1) >> 8)) &
0x60;
- report = report >> 5;
+ report >>= 5;
switch (report) {
case 0x3:
rx_pwr_all = -40 - ((pcck_buf->cck_agc_rpt &
@@ -1039,7 +1039,7 @@ static int recvbuf2recvframe(struct _adapter *padapter, struct sk_buff *pskb)
frag = (le32_to_cpu(prxstat->rxdw2) >> 12) & 0xf;
/* uint 2^3 = 8 bytes */
drvinfo_sz = (le32_to_cpu(prxstat->rxdw0) & 0x000f0000) >> 16;
+ drvinfo_sz <<= 3;
if (pkt_len <= 0)
goto _exit_recvbuf2recvframe;
/* Qos data, wireless lan header length is 26 */ |
u16 drvinfo_sz = 0;
+ drvinfo_sz <<= 3;
/*TODO:
* Offset 0 */
+ drvinfo_sz <<= 3;
do {
if (!cck_highpwr) {
+ report >>= 6;
switch (report) {
} else {
0x60;
+ report >>= 5;
switch (report) {
case 0x3:
+ drvinfo_sz <<= 3;
if (pkt_len <= 0)
