net: stmmac: Use setup_timer and mod_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use timer API functions setup_timer and mod_timer instead
of structure assignments as they are standard way to set
the timer and to update the expire field of an active timer
respectively.
This is done using Coccinelle and semantic patch used for
this is as follows:
expression x,y,z,a,b;
-init_timer (&x);
+setup_timer (&x, y, z);
+mod_timer (&a, b);
-x.function = y;
-x.data = z;
-x.expires = b;
-add_timer(&a);
Signed-off-by: Vaishali Thakkar
 drivers/net/ethernet/stmicro/stmmac/stmmac_main.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c b/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
index 55e89b3..a0ea84f 100644
--- a/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
+++ b/drivers/net/ethernet/stmicro/stmmac/stmmac_main.c
@@ -310,11 +310,11 @@ bool stmmac_eee_init(struct stmmac_priv *priv)
 		spin_lock_irqsave(&priv->lock, flags);
 		if (!priv->eee_active) {
 			priv->eee_active = 1;
-			init_timer(&priv->eee_ctrl_timer);
-			priv->eee_ctrl_timer.function = stmmac_eee_ctrl_timer;
-			priv->eee_ctrl_timer.data = (unsigned long)priv;
-			priv->eee_ctrl_timer.expires = STMMAC_LPI_T(eee_timer);
-			add_timer(&priv->eee_ctrl_timer);
+			setup_timer(&priv->eee_ctrl_timer,
+				    stmmac_eee_ctrl_timer,
+				    (unsigned long)priv);
+			mod_timer(&priv->eee_ctrl_timer,
+				  STMMAC_LPI_T(eee_timer));
 			priv->hw->mac->set_eee_timer(priv->hw,
 						     STMMAC_DEFAULT_LIT_LS,
BtrLinux
Privacy Overview
