staging: lustre: obdclass: remove unused variable
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch removes a variable that was simply used to
store the return value of a function call before
returning it.
The issue was detected and resolved using the following
coccinelle script:
identifier len,f;
-int len;
 ... when != len
     when strict
-len =
+return
        f(...);
-return len;
Signed-off-by: Aya Mahfouz
 drivers/staging/lustre/lustre/obdclass/dt_object.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/lustre/lustre/obdclass/dt_object.c b/drivers/staging/lustre/lustre/obdclass/dt_object.c
index e7be26e..b1eee0a 100644
--- a/drivers/staging/lustre/lustre/obdclass/dt_object.c
+++ b/drivers/staging/lustre/lustre/obdclass/dt_object.c
@@ -424,11 +424,8 @@ EXPORT_SYMBOL(dt_find_or_create);
 /* dt class init function. */
 int dt_global_init(void)
-	int result;
 	LU_CONTEXT_KEY_INIT(&dt_key);
-	result = lu_context_key_register(&dt_key);
-	return result;
+	return lu_context_key_register(&dt_key);
 void dt_global_fini(void)
BtrLinux
Privacy Overview
