staging: lustre: lclient: remove extra parentheses around right bit shift operation
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operations.
The cases handled here are when the resultant value is assigned
to a variable. The issue was detected and resolved using the
following coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
drivers/staging/lustre/lustre/lclient/lcommon_cl.c | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/lustre/lustre/lclient/lcommon_cl.c b/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
index 23095bb..ab6cb41 100644
--- a/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
+++ b/drivers/staging/lustre/lustre/lclient/lcommon_cl.c
@@ -828,7 +828,8 @@ int ccc_prep_size(const struct lu_env *env, struct cl_object *obj,
* --bug 17336 */
loff_t size = cl_isize_read(inode);
loff_t cur_index = start >> PAGE_CACHE_SHIFT;
- loff_t size_index = ((size - 1) >> PAGE_CACHE_SHIFT);
+ loff_t size_index = (size - 1) >>
+ PAGE_CACHE_SHIFT;
if ((size == 0 && cur_index != 0) ||
size_index < cur_index)
@@ -1263,7 +1264,7 @@ __u32 cl_fid_build_gen(const struct lu_fid *fid)
return gen;
- gen = (fid_flatten(fid) >> 32);
+ gen = fid_flatten(fid) >> 32;
return gen;
* --bug 17336 */
+ PAGE_CACHE_SHIFT;
return gen;
return gen;
