Staging: comedi: clean dev_err logging
Author: Haneen Mohammed <hamohammed.sa@gmail.com>
This patch removes  __func__ from dev_err. dev_err includes information about:
(devcice, driver, specific instance of device, etc) in the log printout.
This was done using Coccinelle, with the following semantic patch:
@a@
expression E, R;
expression  msg;
dev_err(E, msg, __func__, R);
@script:python b@
e << a.msg;
y;
if(e.find("%s: ") == True):
	m = e.replace("%s: ", "", 1);
	coccinelle.y = m;
elif(e.find("%s ") == True):
	m = e.replace("%s ", "", 1);
	coccinelle.y = m;
elif(e.find("%s:") == True):
	m = e.replace("%s:", "", 1);
	coccinelle.y = m;
else:
	m = e.replace("%s", "",1);
	coccinelle.y = m;
@c@
expression a.E, a.msg, a.R;
identifier  b.y;
- dev_err(E, msg, __func__, R);
+ dev_err(E, y, R);
Signed-off-by: Haneen Mohammed
 drivers/staging/comedi/drivers/ni_mio_common.c |  4 ++--
 drivers/staging/comedi/drivers/usbduxsigma.c   | 26 +++++++++++---------------
 2 files changed, 13 insertions(+), 17 deletions(-)
diff --git a/drivers/staging/comedi/drivers/ni_mio_common.c b/drivers/staging/comedi/drivers/ni_mio_common.c
index 176b64a..97728d2 100644
--- a/drivers/staging/comedi/drivers/ni_mio_common.c
+++ b/drivers/staging/comedi/drivers/ni_mio_common.c
@@ -670,8 +670,8 @@ static inline void ni_set_bitfield(struct comedi_device *dev, int reg,
 		ni_writeb(dev, devpriv->g0_g1_select_reg, G0_G1_Select);
 		break;
 	default:
-		dev_err(dev->class_dev,
-			"%s called with invalid register %d\n", __func__, reg);
+		dev_err(dev->class_dev, "called with invalid register %d\n",
+			reg);
 		break;
 	mmiowb();
diff --git a/drivers/staging/comedi/drivers/usbduxsigma.c b/drivers/staging/comedi/drivers/usbduxsigma.c
index 394969b..f50cf8a 100644
--- a/drivers/staging/comedi/drivers/usbduxsigma.c
+++ b/drivers/staging/comedi/drivers/usbduxsigma.c
@@ -243,9 +243,8 @@ static void usbduxsigma_ai_handle_urb(struct comedi_device *dev,
 		urb->dev = comedi_to_usb_dev(dev);
 		ret = usb_submit_urb(urb, GFP_ATOMIC);
 		if (ret < 0) {
-				"%s: urb resubmit failed (%d)\n",
-				__func__, ret);
+			dev_err(dev->class_dev, "urb resubmit failed (%d)\n",
+				ret);
 			if (ret == -EL2NSYNC)
 					"buggy USB host controller or bug in IRQ handler\n");
@@ -292,8 +291,8 @@ static void usbduxsigma_ai_urb_complete(struct urb *urb)
 	default:
 		/* a real error */
-		dev_err(dev->class_dev, "%s: non-zero urb status (%d)\n",
-			__func__, urb->status);
+		dev_err(dev->class_dev, "non-zero urb status (%d)\n",
+			urb->status);
 		async->events |= COMEDI_CB_ERROR;
 		break;
@@ -386,9 +385,8 @@ static void usbduxsigma_ao_handle_urb(struct comedi_device *dev,
 		urb->iso_frame_desc[0].status = 0;
 		if (ret < 0) {
-				__func__, ret);
+				ret);
@@ -423,8 +421,8 @@ static void usbduxsigma_ao_urb_complete(struct urb *urb)
 	default:
 		/* a real error */
+			urb->status);
 		break;
@@ -1071,9 +1069,8 @@ static void usbduxsigma_pwm_urb_complete(struct urb *urb)
 	default:
 		/* a real error */
 		if (devpriv->pwm_cmd_running) {
-				"%s: non-zero urb status (%d)\n",
+				urb->status);
 			usbduxsigma_pwm_stop(dev, 0);	/* w/o unlink */
 		return;
@@ -1087,8 +1084,7 @@ static void usbduxsigma_pwm_urb_complete(struct urb *urb)
 	urb->status = 0;
 	if (ret < 0) {
-		dev_err(dev->class_dev, "%s: urb resubmit failed (%d)\n",
-			__func__, ret);
+		dev_err(dev->class_dev, "urb resubmit failed (%d)\n", ret);
BtrLinux
Privacy Overview
