drivers: staging: rtl8188eu: core: Removed unnecessary parentheses
Author: Tina Johnson <tinajohnson.1234@gmail.com>
Parentheses around the right side of an assignment statement are
unnecessary and hence removed. Coccinelle was used to produce the
patch:
@rule1@
identifier x,y;
constant c;
 x =
 y << c
 x =
 y >> c
 x =
 y + c
 x =
 y - c
Signed-off-by: Tina Johnson
 drivers/staging/rtl8188eu/core/rtw_security.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/rtl8188eu/core/rtw_security.c b/drivers/staging/rtl8188eu/core/rtw_security.c
index f8981f5..cc66997 100644
--- a/drivers/staging/rtl8188eu/core/rtw_security.c
+++ b/drivers/staging/rtl8188eu/core/rtw_security.c
@@ -1122,7 +1122,7 @@ static int aes_cipher(u8 *key, uint hdrlen, u8 *pframe, uint plen)
 	num_blocks = plen / 16;
 	/* Find start of payload */
-	payload_index = (hdrlen + 8);
+	payload_index = hdrlen + 8;
 	/* Calculate MIC */
 	aes128k128d(key, mic_iv, aes_out);
@@ -1366,7 +1366,7 @@ static int aes_decipher(u8 *key, uint	hdrlen,
 	num_blocks = (plen-8) / 16;
 	/* Calculate MIC */
BtrLinux
Privacy Overview
