Author: Somya Anand <somyaanand214@gmail.com>
Code using doubly linked list is iterated generally using list_empty and
list_entry functions, but it can be better written using list_for_each_entry
macro.
This patch replaces the while loop containing list_empty and list_entry with
list_for_each_entry and list_for_each_entry_safe. list_for_each_entry is a
macro which is used to iterate over a list of given type. So while loop used to
iterate over a list can be replaced with list_for_each_entry macro. However, if
list_del is used in the loop, then list_for_each_entry_safe is a better choice.
This transformation is done by using the following coccinelle script.
@ rule1 @
expression E1;
identifier I1, I2;
type T;
iterator name list_for_each_entry;
- while (list_empty(&E1) == 0)
+ list_for_each_entry (I1, &E1, I2)
...when != T *I1;
- I1 = list_entry(E1.next, T, I2);
...when != list_del(...);
when != list_del_init(...);
@ rule2 @
expression E1;
identifier I1, I2;
type T;
iterator name list_for_each_entry_safe;
T *I1;
+ T *tmp;
+ list_for_each_entry_safe (I1, tmp, &E1, I2)
...when != T *I1;
Signed-off-by: Somya Anand
drivers/staging/emxx_udc/emxx_udc.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/staging/emxx_udc/emxx_udc.c b/drivers/staging/emxx_udc/emxx_udc.c
index 35dc1c4..561d47e0 100644
--- a/drivers/staging/emxx_udc/emxx_udc.c
+++ b/drivers/staging/emxx_udc/emxx_udc.c
@@ -2229,8 +2229,7 @@ static int _nbu2ss_nuke(struct nbu2ss_udc *udc,
return 0;
/* called with irqs blocked */
- while (!list_empty(&ep->queue)) {
- req = list_entry(ep->queue.next, struct nbu2ss_req, queue);
+ list_for_each_entry(req, &ep->queue, queue) {
_nbu2ss_ep_done(ep, req, status);
return 0;
