drivers/macintosh: Delete an unnecessary check before the function call “of_node_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The of_node_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Benjamin Herrenschmidt
 drivers/macintosh/smu.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/macintosh/smu.c b/drivers/macintosh/smu.c
index 10ae69b..d531f80 100644
--- a/drivers/macintosh/smu.c
+++ b/drivers/macintosh/smu.c
@@ -557,8 +557,7 @@ int __init smu_init (void)
 	return 0;
 fail_msg_node:
-	if (smu->msg_node)
-		of_node_put(smu->msg_node);
+	of_node_put(smu->msg_node);
 fail_db_node:
 	of_node_put(smu->db_node);
 fail_bootmem:
BtrLinux
Privacy Overview
