drivers/net/mv643xx_eth.c: Use FIELD_SIZEOF
Robert P.J. Day proposed to use the macro FIELD_SIZEOF in replace of code
that matches its definition.
The modification was made using the following semantic patch
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
#include
@depends on haskernel@
type t;
identifier f;
- (sizeof(((t*)0)->f))
+ FIELD_SIZEOF(t, f)
type t;
identifier f;
- sizeof(((t*)0)->f)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: Jeff Garzik
 drivers/net/mv643xx_eth.c | 2 +-
diff --git a/drivers/net/mv643xx_eth.c b/drivers/net/mv643xx_eth.c
index 771139e..d65cade 100644
--- a/drivers/net/mv643xx_eth.c
+++ b/drivers/net/mv643xx_eth.c
@@ -3156,7 +3156,7 @@ struct mv643xx_stats {
 	int stat_offset;
-#define MV643XX_STAT(m) sizeof(((struct mv643xx_private *)0)->m), \
+#define MV643XX_STAT(m) FIELD_SIZEOF(struct mv643xx_private, m), \
 					offsetof(struct mv643xx_private, m)
 static const struct mv643xx_stats mv643xx_gstrings_stats[] = {
BtrLinux
Privacy Overview
