[ALSA] sound/pci: remove unused variable
The variable is_capture is initialized but never used otherwise.
(http://www.emn.fr/x-info/coccinelle/)
type T;
identifier i;
constant C;
extern T i;
- T i;
  <+... when != i
- i = C;
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/pci/pcxhr/pcxhr.c | 3 ---
 1 file changed, 3 deletions(-)
diff --git a/sound/pci/pcxhr/pcxhr.c b/sound/pci/pcxhr/pcxhr.c
index 9d5bb76..beed581 100644
--- a/sound/pci/pcxhr/pcxhr.c
+++ b/sound/pci/pcxhr/pcxhr.c
@@ -846,7 +846,6 @@ static int pcxhr_open(struct snd_pcm_substream *subs)
 	struct pcxhr_mgr       *mgr = chip->mgr;
 	struct snd_pcm_runtime *runtime = subs->runtime;
 	struct pcxhr_stream    *stream;
-	int                 is_capture;
 	mutex_lock(&mgr->setup_mutex);
@@ -856,12 +855,10 @@ static int pcxhr_open(struct snd_pcm_substream *subs)
 	if( subs->stream == SNDRV_PCM_STREAM_PLAYBACK ) {
 		snd_printdd("pcxhr_open playback chip%d subs%d\n",
 			    chip->chip_idx, subs->number);
-		is_capture = 0;
 		stream = &chip->playback_stream[subs->number];
 	} else {
 		snd_printdd("pcxhr_open capture chip%d subs%d\n",
-		is_capture = 1;
 		if (mgr->mono_capture)
 			runtime->hw.channels_max = 1;
 		else
BtrLinux
