fs/reiserfs: use an IS_ERR test rather than a NULL test
Author: Julien Brunel <brunel@diku.dk>
In case of error, the function open_xa_dir returns an ERR pointer, but
never returns a NULL pointer.  So a NULL test that comes after an IS_ERR
test should be deleted.
The semantic match that finds this problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@match_bad_null_test@
expression x, E;
statement S1,S2;
x = open_xa_dir(...)
... when != x = E
*  if (x == NULL && ...) S1 else S2
*  if (x == NULL || ...) S1 else S2
Signed-off-by: Julien Brunel
Signed-off-by: Julia Lawall
Cc: Jeff Mahoney
Cc: Jan Kara
Signed-off-by: Andrew Morton
Signed-off-by: Linus Torvalds
 fs/reiserfs/xattr.c | 2 +-
diff --git a/fs/reiserfs/xattr.c b/fs/reiserfs/xattr.c
index bb3cb5b..ad92461 100644
--- a/fs/reiserfs/xattr.c
+++ b/fs/reiserfs/xattr.c
@@ -155,7 +155,7 @@ static struct dentry *get_xa_file_dentry(const struct inode *inode,
 	xadir = open_xa_dir(inode, flags);
 	if (IS_ERR(xadir)) {
 		return ERR_CAST(xadir);
-	} else if (xadir && !xadir->d_inode) {
+	} else if (!xadir->d_inode) {
 		dput(xadir);
 		return ERR_PTR(-ENODATA);
BtrLinux
Privacy Overview
