The function snd_mixart_create creates a link between mgr and card that
allows snd_mixart_free to free card as well.  But if snd_mixart_create
fails, then the link has not been created and card has to be freed explicitly.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S,S1;
position p1,p2,p3;
expression E,E1;
type T,T1;
expression *ptr != NULL;
 if ((x@p1 = snd_card_new(...)) == NULL) S
 x@p1 = snd_card_new(...);
 ... when != snd_card_free(...,(T)x,...)
     when != if (...) { <+... snd_card_free(...,(T)x,...) ...+> }
     when != true x == NULL || ...
     when != x = E
     when != E = (T)x
     when any
 if (x == NULL || ...) S1
 if@p2 (...) {
  ... when != snd_card_free(...,(T1)x,...)
      when != if (...) { <+... snd_card_free(...,(T1)x,...) ...+> }
      when != x = E1
      when != E1 = (T1)x
  return \(0\|<+...x...+>\|ptr\);
  return@p3 ...;
@ script:python @
p1 << r.p1;
p3 << r.p3;
print "* file: %s snd_card_new: %s return: %s" % (p1[0].file,p1[0].line,p3[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/pci/mixart/mixart.c | 4 +++-
 sound/pci/pcxhr/pcxhr.c   | 4 +++-
 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/sound/pci/mixart/mixart.c b/sound/pci/mixart/mixart.c
index 2d0dce6..fd9a117 100644
--- a/sound/pci/mixart/mixart.c
+++ b/sound/pci/mixart/mixart.c
@@ -1010,7 +1010,7 @@ static int __devinit snd_mixart_create(struct mixart_mgr *mgr, struct snd_card *
 		.dev_free = snd_mixart_chip_dev_free,
-	mgr->chip[idx] = chip = kzalloc(sizeof(*chip), GFP_KERNEL);
+	chip = kzalloc(sizeof(*chip), GFP_KERNEL);
 	if (! chip) {
 		snd_printk(KERN_ERR "cannot allocate chip\n");
 		return -ENOMEM;
@@ -1025,6 +1025,7 @@ static int __devinit snd_mixart_create(struct mixart_mgr *mgr, struct snd_card *
 		return err;
+	mgr->chip[idx] = chip;
 	snd_card_set_dev(card, &mgr->pci->dev);
 	return 0;
@@ -1378,6 +1379,7 @@ static int __devinit snd_mixart_probe(struct pci_dev *pci,
 		sprintf(card->longname, "%s [PCM #%d]", mgr->longname, i);
 		if ((err = snd_mixart_create(mgr, card, i)) < 0) {
+			snd_card_free(card);
 			snd_mixart_free(mgr);
 			return err;
diff --git a/sound/pci/pcxhr/pcxhr.c b/sound/pci/pcxhr/pcxhr.c
index 0e06c6c..5862120 100644
--- a/sound/pci/pcxhr/pcxhr.c
+++ b/sound/pci/pcxhr/pcxhr.c
@@ -1024,7 +1024,7 @@ static int __devinit pcxhr_create(struct pcxhr_mgr *mgr, struct snd_card *card,
 		.dev_free = pcxhr_chip_dev_free,
 	if (! chip) {
 		return -ENOMEM;
@@ -1050,6 +1050,7 @@ static int __devinit pcxhr_create(struct pcxhr_mgr *mgr, struct snd_card *card,
 		return err;
 	return 0;
@@ -1307,6 +1308,7 @@ static int __devinit pcxhr_probe(struct pci_dev *pci, const struct pci_device_id
 		if ((err = pcxhr_create(mgr, card, i)) < 0) {
 			pcxhr_free(mgr);
 			return err;
 	if (! chip) {
 		return -ENOMEM;
 		return err;
 	return 0;
 			return err;
 	if (! chip) {
 		return -ENOMEM;
 		return err;
 	return 0;
 			pcxhr_free(mgr);
 			return err;
