drivers/isdn/mISDN: use ARRAY_SIZE
ARRAY_SIZE is more concise to use when the size of an array is divided by
the size of its type or the size of its first element.
(http://www.emn.fr/x-info/coccinelle/)
@i@
#include
@depends on i using "paren.iso"@
type T;
T[] E;
- (sizeof(E)/sizeof(T))
+ ARRAY_SIZE(E)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
 drivers/isdn/mISDN/dsp_hwec.c | 2 +-
diff --git a/drivers/isdn/mISDN/dsp_hwec.c b/drivers/isdn/mISDN/dsp_hwec.c
index eb892d9..806a997 100644
--- a/drivers/isdn/mISDN/dsp_hwec.c
+++ b/drivers/isdn/mISDN/dsp_hwec.c
@@ -43,7 +43,7 @@ static struct mISDN_dsp_element dsp_hwec_p = {
 	.free = NULL,
 	.process_tx = NULL,
 	.process_rx = NULL,
-	.num_args = sizeof(args) / sizeof(struct mISDN_dsp_element_arg),
+	.num_args = ARRAY_SIZE(args),
 	.args = args,
 struct mISDN_dsp_element *dsp_hwec = &dsp_hwec_p; |
 	.free = NULL,
 	.process_tx = NULL,
 	.process_rx = NULL,
 	.args = args,
