[MTD] drivers/mtd/maps/nettel.c: use ARRAY_SIZE
ARRAY_SIZE is more concise to use when the size of an array is divided by
the size of its type or the size of its first element.
(http://www.emn.fr/x-info/coccinelle/)
@i@
#include
@depends on i using "paren.iso"@
type T;
T[] E;
- (sizeof(E)/sizeof(E[...]))
+ ARRAY_SIZE(E)
Signed-off-by: Julia Lawall
Signed-off-by: Andrew Morton
Signed-off-by: David Woodhouse
 drivers/mtd/maps/nettel.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/mtd/maps/nettel.c b/drivers/mtd/maps/nettel.c
index a8723a6..df68266 100644
--- a/drivers/mtd/maps/nettel.c
+++ b/drivers/mtd/maps/nettel.c
@@ -362,8 +362,7 @@ static int __init nettel_init(void)
 	intel_mtd->owner = THIS_MODULE;
-	num_intel_partitions = sizeof(nettel_intel_partitions) /
-		sizeof(nettel_intel_partitions[0]);
+	num_intel_partitions = ARRAY_SIZE(nettel_intel_partitions);
 	if (intelboot) {
 	if (intelboot) {
