arch/avr32: Eliminate NULL test and memset after alloc_bootmem
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b,
alloc_bootmem and related functions never return NULL and always return a
zeroed region of memory. Thus a NULL test or memset after calls to these
functions is unnecessary.
This was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
expression E;
statement S;
E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\|alloc_bootmem_node\|alloc_bootmem_low_pages_node\|alloc_bootmem_pages_node\)(...)
... when != E
- BUG_ON (E == NULL);
- if (E == NULL) S
expression E,E1;
... when != E
- memset(E,0,E1);
Signed-off-by: Julia Lawall
Signed-off-by: Haavard Skinnemoen
arch/avr32/mm/init.c | 1 -
1 file changed, 1 deletion(-)
diff --git a/arch/avr32/mm/init.c b/arch/avr32/mm/init.c
index fa92ff6..e819fa6 100644
--- a/arch/avr32/mm/init.c
+++ b/arch/avr32/mm/init.c
@@ -97,7 +97,6 @@ void __init paging_init(void)
mem_map = NODE_DATA(0)->node_mem_map;
- memset(zero_page, 0, PAGE_SIZE);
empty_zero_page = virt_to_page(zero_page);
flush_dcache_page(empty_zero_page);
