powerpc/52xx: Use DEFINE_SPINLOCK
SPIN_LOCK_UNLOCKED is deprecated. The following makes the change suggested
in Documentation/spinlocks.txt
(http://www.emn.fr/x-info/coccinelle/)
declarer name DEFINE_SPINLOCK;
identifier xxx_lock;
- spinlock_t xxx_lock = SPIN_LOCK_UNLOCKED;
+ DEFINE_SPINLOCK(xxx_lock);
Signed-off-by: Julia Lawall
Signed-off-by: Benjamin Herrenschmidt
arch/powerpc/platforms/52xx/mpc52xx_common.c | 2 +-
diff --git a/arch/powerpc/platforms/52xx/mpc52xx_common.c b/arch/powerpc/platforms/52xx/mpc52xx_common.c
index ae7c34f..98367a0 100644
--- a/arch/powerpc/platforms/52xx/mpc52xx_common.c
+++ b/arch/powerpc/platforms/52xx/mpc52xx_common.c
@@ -42,7 +42,7 @@ static struct of_device_id mpc52xx_bus_ids[] __initdata = {
* from interrupt context while node mapping (which calls ioremap())
* cannot be used at such point.
-static spinlock_t mpc52xx_lock = SPIN_LOCK_UNLOCKED;
+static DEFINE_SPINLOCK(mpc52xx_lock);
static struct mpc52xx_gpt __iomem *mpc52xx_wdt;
static struct mpc52xx_cdm __iomem *mpc52xx_cdm; |
