arch/arm/plat-iop: Use DIV_ROUND_CLOSEST
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
#include
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
Signed-off-by: Julia Lawall
Signed-off-by: Dan Williams
 arch/arm/plat-iop/time.c | 2 +-
diff --git a/arch/arm/plat-iop/time.c b/arch/arm/plat-iop/time.c
index 3695bbe..8da95d5 100644
--- a/arch/arm/plat-iop/time.c
+++ b/arch/arm/plat-iop/time.c
@@ -85,7 +85,7 @@ void __init iop_init_time(unsigned long tick_rate)
 	u32 timer_ctl;
-	ticks_per_jiffy = (tick_rate + HZ/2) / HZ;
+	ticks_per_jiffy = DIV_ROUND_CLOSEST(tick_rate, HZ);
 	ticks_per_usec = tick_rate / 1000000;
 	next_jiffy_time = 0xffffffff;
 	iop_tick_rate = tick_rate;
