V4L/DVB (13012): uvc: introduce missing kfree
Move the kzalloc and associated test after the stream/query test, to avoid
the need to free the allocated if the stream/query test fails.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f1 = E
 (x->f1 == NULL || ...)
 f(...,x->f1,...)
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Acked-by: Laurent Pinchart
Signed-off-by: Douglas Schilling Landgraf
Signed-off-by: Mauro Carvalho Chehab
 drivers/media/video/uvc/uvc_video.c | 7 ++++---
 1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/media/video/uvc/uvc_video.c b/drivers/media/video/uvc/uvc_video.c
index 5b757f3..f960e8e 100644
--- a/drivers/media/video/uvc/uvc_video.c
+++ b/drivers/media/video/uvc/uvc_video.c
@@ -124,13 +124,14 @@ static int uvc_get_video_ctrl(struct uvc_streaming *stream,
 	int ret;
 	size = stream->dev->uvc_version >= 0x0110 ? 34 : 26;
+	if ((stream->dev->quirks & UVC_QUIRK_PROBE_DEF) &&
+			query == UVC_GET_DEF)
+		return -EIO;
 	data = kmalloc(size, GFP_KERNEL);
 	if (data == NULL)
 		return -ENOMEM;
-	if ((stream->dev->quirks & UVC_QUIRK_PROBE_DEF) && query == UVC_GET_DEF)
-		return -EIO;
 	ret = __uvc_query_ctrl(stream->dev, query, 0, stream->intfnum,
 		probe ? UVC_VS_PROBE_CONTROL : UVC_VS_COMMIT_CONTROL, data,
 		size, UVC_CTRL_STREAMING_TIMEOUT);
BtrLinux
Privacy Overview
