perf tools: Correct size given to memset
Memset should be given the size of the structure, not the size
of the pointer.
(http://coccinelle.lip6.fr/)
type T;
T *x;
expression E;
memset(x, E, sizeof(
x))
Signed-off-by: Julia Lawall
Cc: Peter Zijlstra
Cc: Paul Mackerras
LKML-Reference:
Signed-off-by: Ingo Molnar
tools/perf/util/probe-event.c | 2 +-
tools/perf/util/trace-event-parse.c | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/tools/perf/util/probe-event.c b/tools/perf/util/probe-event.c
index 9480d99..d14a458 100644
--- a/tools/perf/util/probe-event.c
+++ b/tools/perf/util/probe-event.c
@@ -376,7 +376,7 @@ static void clear_probe_point(struct probe_point *pp)
free(pp->args);
for (i = 0; i < pp->found; i++)
free(pp->probes[i]);
- memset(pp, 0, sizeof(pp));
+ memset(pp, 0, sizeof(*pp));
/* Show an event */
diff --git a/tools/perf/util/trace-event-parse.c b/tools/perf/util/trace-event-parse.c
index 6ffe9d6..c5c32be 100644
--- a/tools/perf/util/trace-event-parse.c
+++ b/tools/perf/util/trace-event-parse.c
@@ -1477,7 +1477,7 @@ process_fields(struct event *event, struct print_flag_sym **list, char **tok)
goto out_free;
field = malloc_or_die(sizeof(*field));
- memset(field, 0, sizeof(field));
+ memset(field, 0, sizeof(*field));
value = arg_eval(arg);
field->value = strdup(value); |
free(pp->args);
/* Show an event */
goto out_free;
