drivers/isdn: eliminate duplicated test
The code checked slot_rx twice.  Check slot_tx by analogy with the bank
case.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
expression E;
*E && E
*E || E
Signed-off-by: Julia Lawall
Cc: Karsten Keil
Signed-off-by: Andrew Morton
 drivers/isdn/hardware/mISDN/hfcmulti.c | 2 +-
diff --git a/drivers/isdn/hardware/mISDN/hfcmulti.c b/drivers/isdn/hardware/mISDN/hfcmulti.c
index a6624ad..1a1420d 100644
--- a/drivers/isdn/hardware/mISDN/hfcmulti.c
+++ b/drivers/isdn/hardware/mISDN/hfcmulti.c
@@ -3152,7 +3152,7 @@ static void
 hfcmulti_pcm(struct hfc_multi *hc, int ch, int slot_tx, int bank_tx,
     int slot_rx, int bank_rx)
-	if (slot_rx < 0 || slot_rx < 0 || bank_tx < 0 || bank_rx < 0) {
+	if (slot_tx < 0 || slot_rx < 0 || bank_tx < 0 || bank_rx < 0) {
 		/* disable PCM */
 		mode_hfcmulti(hc, ch, hc->chan[ch].protocol, -1, 0, -1, 0);
 		return;
BtrLinux
Privacy Overview
