crypto: Make Open Firmware device id constant
Author: Márton Németh <nm127@freemail.hu>
The match_table field of the struct of_device_id is constant in
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Cc: cocci@diku.dk
Signed-off-by: Herbert Xu
 drivers/crypto/amcc/crypto4xx_core.c | 2 +-
 drivers/crypto/talitos.c             | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/crypto/amcc/crypto4xx_core.c b/drivers/crypto/amcc/crypto4xx_core.c
index 46e899a..1c3849f 100644
--- a/drivers/crypto/amcc/crypto4xx_core.c
+++ b/drivers/crypto/amcc/crypto4xx_core.c
@@ -1274,7 +1274,7 @@ static int __exit crypto4xx_remove(struct of_device *ofdev)
 	return 0;
-static struct of_device_id crypto4xx_match[] = {
+static const struct of_device_id crypto4xx_match[] = {
 	{ .compatible      = "amcc,ppc4xx-crypto",},
diff --git a/drivers/crypto/talitos.c b/drivers/crypto/talitos.c
index c47ffe8..fd529d6 100644
--- a/drivers/crypto/talitos.c
+++ b/drivers/crypto/talitos.c
@@ -1958,7 +1958,7 @@ err_out:
 	return err;
-static struct of_device_id talitos_match[] = {
+static const struct of_device_id talitos_match[] = {
 		.compatible = "fsl,sec2.0",
BtrLinux
Privacy Overview
