i2c: Make PCI device ids constant
Author: Márton Németh <nm127@freemail.hu>
The id_table field of the struct pci_driver is constant in
so it is worth to make initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
(http://coccinelle.lip6.fr/)
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
	struct I1 {
	  const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
	struct I1 y = {
	  .x = E,
@c@
identifier r.I2;
identifier s.E;
	const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+	const
	struct I2 E[] = ...;
Signed-off-by: Márton Németh
Cc: Julia Lawall
Signed-off-by: Jean Delvare
 drivers/i2c/busses/i2c-ali1535.c  | 2 +-
 drivers/i2c/busses/i2c-ali1563.c  | 2 +-
 drivers/i2c/busses/i2c-ali15x3.c  | 2 +-
 drivers/i2c/busses/i2c-amd756.c   | 2 +-
 drivers/i2c/busses/i2c-amd8111.c  | 2 +-
 drivers/i2c/busses/i2c-hydra.c    | 2 +-
 drivers/i2c/busses/i2c-i801.c     | 2 +-
 drivers/i2c/busses/i2c-isch.c     | 2 +-
 drivers/i2c/busses/i2c-nforce2.c  | 2 +-
 drivers/i2c/busses/i2c-pasemi.c   | 2 +-
 drivers/i2c/busses/i2c-piix4.c    | 2 +-
 drivers/i2c/busses/i2c-sis5595.c  | 2 +-
 drivers/i2c/busses/i2c-sis630.c   | 2 +-
 drivers/i2c/busses/i2c-sis96x.c   | 2 +-
 drivers/i2c/busses/i2c-tiny-usb.c | 2 +-
 drivers/i2c/busses/i2c-via.c      | 2 +-
 drivers/i2c/busses/i2c-viapro.c   | 2 +-
 17 files changed, 17 insertions(+), 17 deletions(-)
diff --git a/drivers/i2c/busses/i2c-ali1535.c b/drivers/i2c/busses/i2c-ali1535.c
index 8de7d7b..bd8f1e4 100644
--- a/drivers/i2c/busses/i2c-ali1535.c
+++ b/drivers/i2c/busses/i2c-ali1535.c
@@ -480,7 +480,7 @@ static struct i2c_adapter ali1535_adapter = {
 	.algo		= &smbus_algorithm,
-static struct pci_device_id ali1535_ids[] = {
+static const struct pci_device_id ali1535_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_AL, PCI_DEVICE_ID_AL_M7101) },
diff --git a/drivers/i2c/busses/i2c-ali1563.c b/drivers/i2c/busses/i2c-ali1563.c
index 4687af4..a409cfc 100644
--- a/drivers/i2c/busses/i2c-ali1563.c
+++ b/drivers/i2c/busses/i2c-ali1563.c
@@ -417,7 +417,7 @@ static void __devexit ali1563_remove(struct pci_dev * dev)
 	ali1563_shutdown(dev);
-static struct pci_device_id __devinitdata ali1563_id_table[] = {
+static const struct pci_device_id ali1563_id_table[] __devinitconst = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_AL, PCI_DEVICE_ID_AL_M1563) },
diff --git a/drivers/i2c/busses/i2c-ali15x3.c b/drivers/i2c/busses/i2c-ali15x3.c
index e7e3205..659f63f 100644
--- a/drivers/i2c/busses/i2c-ali15x3.c
+++ b/drivers/i2c/busses/i2c-ali15x3.c
@@ -477,7 +477,7 @@ static struct i2c_adapter ali15x3_adapter = {
-static struct pci_device_id ali15x3_ids[] = {
+static const struct pci_device_id ali15x3_ids[] = {
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-amd756.c b/drivers/i2c/busses/i2c-amd756.c
index 8f0b90e..c5a9fa4 100644
--- a/drivers/i2c/busses/i2c-amd756.c
+++ b/drivers/i2c/busses/i2c-amd756.c
@@ -308,7 +308,7 @@ static const char* chipname[] = {
 	"nVidia nForce", "AMD8111",
-static struct pci_device_id amd756_ids[] = {
+static const struct pci_device_id amd756_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_AMD, PCI_DEVICE_ID_AMD_VIPER_740B),
 	  .driver_data = AMD756 },
 	{ PCI_DEVICE(PCI_VENDOR_ID_AMD, PCI_DEVICE_ID_AMD_VIPER_7413),
diff --git a/drivers/i2c/busses/i2c-amd8111.c b/drivers/i2c/busses/i2c-amd8111.c
index 5b4ad86..d0dc970 100644
--- a/drivers/i2c/busses/i2c-amd8111.c
+++ b/drivers/i2c/busses/i2c-amd8111.c
@@ -351,7 +351,7 @@ static const struct i2c_algorithm smbus_algorithm = {
-static struct pci_device_id amd8111_ids[] = {
+static const struct pci_device_id amd8111_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_AMD, PCI_DEVICE_ID_AMD_8111_SMBUS2) },
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-hydra.c b/drivers/i2c/busses/i2c-hydra.c
index bec9b84..c767295 100644
--- a/drivers/i2c/busses/i2c-hydra.c
+++ b/drivers/i2c/busses/i2c-hydra.c
@@ -105,7 +105,7 @@ static struct i2c_adapter hydra_adap = {
 	.algo_data	= &hydra_bit_data,
-static struct pci_device_id hydra_ids[] = {
+static const struct pci_device_id hydra_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_APPLE, PCI_DEVICE_ID_APPLE_HYDRA) },
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-i801.c b/drivers/i2c/busses/i2c-i801.c
index df6ab553..cefe80c 100644
--- a/drivers/i2c/busses/i2c-i801.c
+++ b/drivers/i2c/busses/i2c-i801.c
@@ -561,7 +561,7 @@ static struct i2c_adapter i801_adapter = {
-static struct pci_device_id i801_ids[] = {
+static const struct pci_device_id i801_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82801AA_3) },
 	{ PCI_DEVICE(PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82801AB_3) },
 	{ PCI_DEVICE(PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82801BA_2) },
diff --git a/drivers/i2c/busses/i2c-isch.c b/drivers/i2c/busses/i2c-isch.c
index dba6eb0..69c22f7 100644
--- a/drivers/i2c/busses/i2c-isch.c
+++ b/drivers/i2c/busses/i2c-isch.c
@@ -256,7 +256,7 @@ static struct i2c_adapter sch_adapter = {
-static struct pci_device_id sch_ids[] = {
+static const struct pci_device_id sch_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_SCH_LPC) },
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-nforce2.c b/drivers/i2c/busses/i2c-nforce2.c
index ec11d1c..4a70058 100644
--- a/drivers/i2c/busses/i2c-nforce2.c
+++ b/drivers/i2c/busses/i2c-nforce2.c
@@ -308,7 +308,7 @@ static struct i2c_algorithm smbus_algorithm = {
-static struct pci_device_id nforce2_ids[] = {
+static const struct pci_device_id nforce2_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_NVIDIA, PCI_DEVICE_ID_NVIDIA_NFORCE2_SMBUS) },
 	{ PCI_DEVICE(PCI_VENDOR_ID_NVIDIA, PCI_DEVICE_ID_NVIDIA_NFORCE2S_SMBUS) },
 	{ PCI_DEVICE(PCI_VENDOR_ID_NVIDIA, PCI_DEVICE_ID_NVIDIA_NFORCE3_SMBUS) },
diff --git a/drivers/i2c/busses/i2c-pasemi.c b/drivers/i2c/busses/i2c-pasemi.c
index adf0fbb..0d20ff4 100644
--- a/drivers/i2c/busses/i2c-pasemi.c
+++ b/drivers/i2c/busses/i2c-pasemi.c
@@ -400,7 +400,7 @@ static void __devexit pasemi_smb_remove(struct pci_dev *dev)
 	kfree(smbus);
-static struct pci_device_id pasemi_smb_ids[] = {
+static const struct pci_device_id pasemi_smb_ids[] = {
 	{ PCI_DEVICE(0x1959, 0xa003) },
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-piix4.c b/drivers/i2c/busses/i2c-piix4.c
index e56e4b6..ee9da6f 100644
--- a/drivers/i2c/busses/i2c-piix4.c
+++ b/drivers/i2c/busses/i2c-piix4.c
@@ -472,7 +472,7 @@ static struct i2c_adapter piix4_adapter = {
-static struct pci_device_id piix4_ids[] = {
+static const struct pci_device_id piix4_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82371AB_3) },
 	{ PCI_DEVICE(PCI_VENDOR_ID_INTEL, PCI_DEVICE_ID_INTEL_82443MX_3) },
 	{ PCI_DEVICE(PCI_VENDOR_ID_EFAR, PCI_DEVICE_ID_EFAR_SLC90E66_3) },
diff --git a/drivers/i2c/busses/i2c-sis5595.c b/drivers/i2c/busses/i2c-sis5595.c
index 844569f..55a7137 100644
--- a/drivers/i2c/busses/i2c-sis5595.c
+++ b/drivers/i2c/busses/i2c-sis5595.c
@@ -369,7 +369,7 @@ static struct i2c_adapter sis5595_adapter = {
-static struct pci_device_id sis5595_ids[] __devinitdata = {
+static const struct pci_device_id sis5595_ids[] __devinitconst = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_SI, PCI_DEVICE_ID_SI_503) },
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-sis630.c b/drivers/i2c/busses/i2c-sis630.c
index 68cff7a..2309c7f 100644
--- a/drivers/i2c/busses/i2c-sis630.c
+++ b/drivers/i2c/busses/i2c-sis630.c
@@ -468,7 +468,7 @@ static struct i2c_adapter sis630_adapter = {
-static struct pci_device_id sis630_ids[] __devinitdata = {
+static const struct pci_device_id sis630_ids[] __devinitconst = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_SI, PCI_DEVICE_ID_SI_LPC) },
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-sis96x.c b/drivers/i2c/busses/i2c-sis96x.c
index 1649963..d43d8f8 100644
--- a/drivers/i2c/busses/i2c-sis96x.c
+++ b/drivers/i2c/busses/i2c-sis96x.c
@@ -245,7 +245,7 @@ static struct i2c_adapter sis96x_adapter = {
-static struct pci_device_id sis96x_ids[] = {
+static const struct pci_device_id sis96x_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_SI, PCI_DEVICE_ID_SI_SMBUS) },
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-tiny-usb.c b/drivers/i2c/busses/i2c-tiny-usb.c
index e29b6d5..41adb39 100644
--- a/drivers/i2c/busses/i2c-tiny-usb.c
+++ b/drivers/i2c/busses/i2c-tiny-usb.c
@@ -137,7 +137,7 @@ static const struct i2c_algorithm usb_algorithm = {
  * Future Technology Devices International Ltd., later a pair was
  * bought from EZPrototypes
-static struct usb_device_id i2c_tiny_usb_table [] = {
+static const struct usb_device_id i2c_tiny_usb_table[] = {
 	{ USB_DEVICE(0x0403, 0xc631) },   /* FTDI */
 	{ USB_DEVICE(0x1c40, 0x0534) },   /* EZPrototypes */
 	{ }                               /* Terminating entry */
diff --git a/drivers/i2c/busses/i2c-via.c b/drivers/i2c/busses/i2c-via.c
index 8b24f19..de78283 100644
--- a/drivers/i2c/busses/i2c-via.c
+++ b/drivers/i2c/busses/i2c-via.c
@@ -89,7 +89,7 @@ static struct i2c_adapter vt586b_adapter = {
-static struct pci_device_id vt586b_ids[] __devinitdata = {
+static const struct pci_device_id vt586b_ids[] __devinitconst = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_82C586_3) },
 	{ 0, }
diff --git a/drivers/i2c/busses/i2c-viapro.c b/drivers/i2c/busses/i2c-viapro.c
index a84a909..d57292e 100644
--- a/drivers/i2c/busses/i2c-viapro.c
+++ b/drivers/i2c/busses/i2c-viapro.c
@@ -444,7 +444,7 @@ release_region:
 	return error;
-static struct pci_device_id vt596_ids[] = {
+static const struct pci_device_id vt596_ids[] = {
 	{ PCI_DEVICE(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_82C596_3),
 	  .driver_data = SMBBA1 },
 	{ PCI_DEVICE(PCI_VENDOR_ID_VIA, PCI_DEVICE_ID_VIA_82C596B_3),
BtrLinux
Privacy Overview
