ALSA: sound/pci/asihpi: Use kzalloc
Use kzalloc rather than the combination of kmalloc and memset.
(http://coccinelle.lip6.fr/)
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
 if (x == NULL) S
-memset(x, 0, size);
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/pci/asihpi/hpi6000.c | 3 +--
 sound/pci/asihpi/hpi6205.c | 3 +--
 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/sound/pci/asihpi/hpi6000.c b/sound/pci/asihpi/hpi6000.c
index 9c50931..839ecb2 100644
--- a/sound/pci/asihpi/hpi6000.c
+++ b/sound/pci/asihpi/hpi6000.c
@@ -448,14 +448,13 @@ static void subsys_create_adapter(struct hpi_message *phm,
 	if (phm->u.s.resource.r.pci->device_id != HPI_PCI_DEV_ID_PCI2040)
 		return;
-	ao.priv = kmalloc(sizeof(struct hpi_hw_obj), GFP_KERNEL);
+	ao.priv = kzalloc(sizeof(struct hpi_hw_obj), GFP_KERNEL);
 	if (!ao.priv) {
 		HPI_DEBUG_LOG(ERROR, "cant get mem for adapter object\n");
 		phr->error = HPI_ERROR_MEMORY_ALLOC;
 		return;
-	memset(ao.priv, 0, sizeof(struct hpi_hw_obj));
 	/* create the adapter object based on the resource information */
 	/*? memcpy(&ao.Pci,&phm->u.s.Resource.r.Pci,sizeof(ao.Pci)); */
 	ao.pci = *phm->u.s.resource.r.pci;
diff --git a/sound/pci/asihpi/hpi6205.c b/sound/pci/asihpi/hpi6205.c
index 8df2ff7..5e88c1f 100644
--- a/sound/pci/asihpi/hpi6205.c
+++ b/sound/pci/asihpi/hpi6205.c
@@ -482,13 +482,12 @@ static void subsys_create_adapter(struct hpi_message *phm,
 	if (phm->u.s.resource.r.pci->device_id != HPI_PCI_DEV_ID_DSP6205)
 		return;
 	if (!ao.priv) {
 		return;
 	err = create_adapter_obj(&ao, &os_error_code);
BtrLinux
Privacy Overview
