drivers/mtd: Use memdup_user
Use memdup_user when user data is immediately copied into the
allocated region.
(http://coccinelle.lip6.fr/)
expression from,to,size,flag;
position p;
identifier l1,l2;
-  to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+  to = memdup_user(from,size);
   if (
-      to==NULL
+      IS_ERR(to)
   <+... when != goto l1;
-  -ENOMEM
+  PTR_ERR(to)
-  if (copy_from_user(to, from, size) != 0) {
-    <+... when != goto l2;
-    -EFAULT
Signed-off-by: Julia Lawall
Signed-off-by: David Woodhouse
 drivers/mtd/mtdchar.c | 11 +++--------
 1 file changed, 3 insertions(+), 8 deletions(-)
diff --git a/drivers/mtd/mtdchar.c b/drivers/mtd/mtdchar.c
index 8bb5e4a..8b223c0 100644
--- a/drivers/mtd/mtdchar.c
+++ b/drivers/mtd/mtdchar.c
@@ -404,14 +404,9 @@ static int mtd_do_writeoob(struct file *file, struct mtd_info *mtd,
 	if (ops.ooboffs && ops.ooblen > (mtd->oobsize - ops.ooboffs))
 		return -EINVAL;
-	ops.oobbuf = kmalloc(length, GFP_KERNEL);
-	if (!ops.oobbuf)
-		return -ENOMEM;
-	if (copy_from_user(ops.oobbuf, ptr, length)) {
-		kfree(ops.oobbuf);
-		return -EFAULT;
+	ops.oobbuf = memdup_user(ptr, length);
+	if (IS_ERR(ops.oobbuf))
+		return PTR_ERR(ops.oobbuf);
 	start &= ~((uint64_t)mtd->oobsize - 1);
 	ret = mtd->write_oob(mtd, start, &ops);
BtrLinux
Privacy Overview
