drivers/net: Eliminate a NULL pointer dereference
At the point of the print, dev is NULL.
@r exists@
expression E,E1;
identifier f;
statement S1,S2,S3;
if ((E == NULL && ...) || ...)
... when != if (...) S1 else S2
when != E = E1
* E->f
... when any
return ...;
else S3
Signed-off-by: Julia Lawall
drivers/net/3c507.c | 3 +--
1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/net/3c507.c b/drivers/net/3c507.c
index 82eaf65..ea9b7a0 100644
--- a/drivers/net/3c507.c
+++ b/drivers/net/3c507.c
@@ -551,8 +551,7 @@ static irqreturn_t el16_interrupt(int irq, void *dev_id)
void __iomem *shmem;
if (dev == NULL) {
- pr_err("%s: net_interrupt(): irq %d for unknown device.\n",
- dev->name, irq);
+ pr_err("net_interrupt(): irq %d for unknown device.\n", irq);
return IRQ_NONE;
if (dev == NULL) {
- dev->name, irq);
return IRQ_NONE;
