staging: Use GFP_ATOMIC when a lock is held
In each case, the containing function is only called from one place, where
a spin lock is held.
(http://coccinelle.lip6.fr/)
@gfp exists@
identifier fn;
position p;
fn(...) {
... when != spin_unlock
    when any
  GFP_KERNEL@p
 ... when any
@locked@
identifier gfp.fn;
spin_lock(...)
fn(...)
@depends on locked@
position gfp.p;
- GFP_KERNEL@p
+ GFP_ATOMIC
Signed-off-by: Julia Lawall
Cc: Jonathan Cameron
Cc: Marek Lindner
Cc: Martyn Welch
 drivers/staging/iio/ring_sw.c              | 2 +-
 drivers/staging/vme/bridges/vme_ca91cx42.c | 2 +-
 drivers/staging/vme/bridges/vme_tsi148.c   | 2 +-
 3 files changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/iio/ring_sw.c b/drivers/staging/iio/ring_sw.c
index 1f14cd4..294272d 100644
--- a/drivers/staging/iio/ring_sw.c
+++ b/drivers/staging/iio/ring_sw.c
@@ -20,7 +20,7 @@ static inline int __iio_allocate_sw_ring_buffer(struct iio_sw_ring_buffer *ring,
 	if ((length == 0) || (bytes_per_datum == 0))
 		return -EINVAL;
 	__iio_update_ring_buffer(&ring->buf, bytes_per_datum, length);
-	ring->data = kmalloc(length*ring->buf.bpd, GFP_KERNEL);
+	ring->data = kmalloc(length*ring->buf.bpd, GFP_ATOMIC);
 	ring->read_p = NULL;
 	ring->write_p = NULL;
 	ring->last_written_p = NULL;
diff --git a/drivers/staging/vme/bridges/vme_ca91cx42.c b/drivers/staging/vme/bridges/vme_ca91cx42.c
index 0c82eb4..0f9ea58 100644
--- a/drivers/staging/vme/bridges/vme_ca91cx42.c
+++ b/drivers/staging/vme/bridges/vme_ca91cx42.c
@@ -523,7 +523,7 @@ static int ca91cx42_alloc_resource(struct vme_master_resource *image,
 	if (image->bus_resource.name == NULL) {
-		image->bus_resource.name = kmalloc(VMENAMSIZ+3, GFP_KERNEL);
+		image->bus_resource.name = kmalloc(VMENAMSIZ+3, GFP_ATOMIC);
 			dev_err(ca91cx42_bridge->parent, "Unable to allocate "
 				"memory for resource name\n");
diff --git a/drivers/staging/vme/bridges/vme_tsi148.c b/drivers/staging/vme/bridges/vme_tsi148.c
index abe88a3..f09cac1 100644
--- a/drivers/staging/vme/bridges/vme_tsi148.c
+++ b/drivers/staging/vme/bridges/vme_tsi148.c
@@ -828,7 +828,7 @@ static int tsi148_alloc_resource(struct vme_master_resource *image,
 		return 0;
 			dev_err(tsi148_bridge->parent, "Unable to allocate "
BtrLinux
Privacy Overview
