powerpc/5200: mpc52xx_uart.c: Add of_node_put to avoid memory leak
Add a call to of_node_put in the error handling code following a call to
of_find_compatible_node.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r exists@
local idexpression x;
expression E,E1;
statement S;
*x =
(of_find_node_by_path
|of_find_node_by_name
|of_find_node_by_phandle
|of_get_parent
|of_get_next_parent
|of_get_next_child
|of_match_node
if (x == NULL) S
<... when != x = E
*if (...) {
  ... when != of_node_put(x)
      when != if (...) { ... of_node_put(x); ... }
  return <+...x...+>;
*  return ...;
of_node_put(x);
Signed-off-by: Julia Lawall
Acked-by: Wolfram Sang
Signed-off-by: Grant Likely
 drivers/serial/mpc52xx_uart.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/serial/mpc52xx_uart.c b/drivers/serial/mpc52xx_uart.c
index 8dedb26..c4399e2 100644
--- a/drivers/serial/mpc52xx_uart.c
+++ b/drivers/serial/mpc52xx_uart.c
@@ -500,6 +500,7 @@ static int __init mpc512x_psc_fifoc_init(void)
 	psc_fifoc = of_iomap(np, 0);
 	if (!psc_fifoc) {
 		pr_err("%s: Can't map FIFOC\n", __func__);
+		of_node_put(np);
 		return -ENODEV;
BtrLinux
Privacy Overview
