drivers/net/sb1000.c: delete double assignment
The other code around these duplicated assignments initializes the 0 1 2
and 3 elements of an array, so change the initialization of the
rx_session_id array to do the same.
expression i;
*i = ...;
 i = ...;
Signed-off-by: Julia Lawall
 drivers/net/sb1000.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/net/sb1000.c b/drivers/net/sb1000.c
index a9ae505..66c2f1a 100644
--- a/drivers/net/sb1000.c
+++ b/drivers/net/sb1000.c
@@ -961,9 +961,9 @@ sb1000_open(struct net_device *dev)
 	lp->rx_error_count = 0;
 	lp->rx_error_dpc_count = 0;
 	lp->rx_session_id[0] = 0x50;
-	lp->rx_session_id[0] = 0x48;
-	lp->rx_session_id[0] = 0x44;
-	lp->rx_session_id[0] = 0x42;
+	lp->rx_session_id[1] = 0x48;
+	lp->rx_session_id[2] = 0x44;
+	lp->rx_session_id[3] = 0x42;
 	lp->rx_frame_id[0] = 0;
 	lp->rx_frame_id[1] = 0;
 	lp->rx_frame_id[2] = 0;
BtrLinux
Privacy Overview
