sound/soc/fsl/p1022_ds.c: add missing of_node_put
dma_channel_np has been accessed at this point, so decrease its reference
count before leaving the function.
identifier x;
expression E1!=0,E2,E3,E4;
statement S;
iterator I;
if (...) { ... when != of_node_put(x)
               when != x = E3
               when != E3 = x
*  return ...;
... when != x = E2
    when != I(...,x,...) S
if (...) { ... when != x = E4
 of_node_put(x); ... return ...; }
Signed-off-by: Julia Lawall
Acked-by: Liam Girdwood
Signed-off-by: Mark Brown
 sound/soc/fsl/p1022_ds.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/sound/soc/fsl/p1022_ds.c b/sound/soc/fsl/p1022_ds.c
index 8fa4d5f..fcb862e 100644
--- a/sound/soc/fsl/p1022_ds.c
+++ b/sound/soc/fsl/p1022_ds.c
@@ -297,8 +297,10 @@ static int get_dma_channel(struct device_node *ssi_np,
 	 * dai->platform name should already point to an allocated buffer.
 	ret = of_address_to_resource(dma_channel_np, 0, &res);
-	if (ret)
+	if (ret) {
+		of_node_put(dma_channel_np);
 		return ret;
 	snprintf((char *)dai->platform_name, DAI_NAME_SIZE, "%llx.%s",
 		 (unsigned long long) res.start, dma_channel_np->name);
BtrLinux
Privacy Overview
