drivers/staging/bcm/DDRInit.c | 26 +++++++++++++-------------
drivers/staging/media/as102/as102_usb_drv.c | 5 ++---
drivers/staging/rtl8192e/rtl8192e/rtl_wx.c | 4 ++--
drivers/staging/rtl8192e/rtllib_wx.c | 2 +-
drivers/staging/rtl8192u/r8192U_wx.c | 4 ++--
drivers/staging/rtl8712/rtl871x_ioctl_linux.c | 4 ++--
drivers/staging/vt6655/wpa.c | 4 ++--
drivers/staging/vt6656/wpa.c | 4 ++--
8 files changed, 26 insertions(+), 27 deletions(-)
diff --git a/drivers/staging/bcm/DDRInit.c b/drivers/staging/bcm/DDRInit.c
index 1c7db81..2b46f4d 100644
--- a/drivers/staging/bcm/DDRInit.c
+++ b/drivers/staging/bcm/DDRInit.c
@@ -1115,20 +1115,20 @@ int download_ddr_settings(PMINI_ADAPTER Adapter)
case DDR_80_MHZ:
psDDRSetting = asT3LP_DDRSetting80MHz;
- RegCount = (sizeof(asT3LP_DDRSetting80MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3LP_DDRSetting80MHz);
RegCount -= T3LP_SKIP_CLOCK_PROGRAM_DUMP_80MHZ ;
psDDRSetting += T3LP_SKIP_CLOCK_PROGRAM_DUMP_80MHZ;
break;
case DDR_100_MHZ:
psDDRSetting = asT3LP_DDRSetting100MHz;
- RegCount = (sizeof(asT3LP_DDRSetting100MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3LP_DDRSetting100MHz);
RegCount -= T3LP_SKIP_CLOCK_PROGRAM_DUMP_100MHZ ;
psDDRSetting += T3LP_SKIP_CLOCK_PROGRAM_DUMP_100MHZ;
break;
case DDR_133_MHZ:
bOverrideSelfRefresh = TRUE;
psDDRSetting = asT3LP_DDRSetting133MHz;
- RegCount = (sizeof(asT3LP_DDRSetting133MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3LP_DDRSetting133MHz);
RegCount -= T3LP_SKIP_CLOCK_PROGRAM_DUMP_133MHZ ;
psDDRSetting += T3LP_SKIP_CLOCK_PROGRAM_DUMP_133MHZ;
break;
@@ -1146,20 +1146,20 @@ int download_ddr_settings(PMINI_ADAPTER Adapter)
case DDR_80_MHZ:
psDDRSetting = asT3LPB_DDRSetting80MHz;
- RegCount=(sizeof(asT3LPB_DDRSetting80MHz)/sizeof(DDR_SET_NODE));
+ RegCount=ARRAY_SIZE(asT3LPB_DDRSetting80MHz);
RegCount -= T3LPB_SKIP_CLOCK_PROGRAM_DUMP_80MHZ ;
psDDRSetting += T3LPB_SKIP_CLOCK_PROGRAM_DUMP_80MHZ;
break;
case DDR_100_MHZ:
psDDRSetting = asT3LPB_DDRSetting100MHz;
- RegCount = (sizeof(asT3LPB_DDRSetting100MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3LPB_DDRSetting100MHz);
RegCount -= T3LPB_SKIP_CLOCK_PROGRAM_DUMP_100MHZ ;
psDDRSetting += T3LPB_SKIP_CLOCK_PROGRAM_DUMP_100MHZ;
break;
case DDR_133_MHZ:
psDDRSetting = asT3LPB_DDRSetting133MHz;
- RegCount = (sizeof(asT3LPB_DDRSetting133MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3LPB_DDRSetting133MHz);
RegCount -= T3LPB_SKIP_CLOCK_PROGRAM_DUMP_133MHZ ;
psDDRSetting += T3LPB_SKIP_CLOCK_PROGRAM_DUMP_133MHZ;
break;
@@ -1167,7 +1167,7 @@ int download_ddr_settings(PMINI_ADAPTER Adapter)
case DDR_160_MHZ:
psDDRSetting = asT3LPB_DDRSetting160MHz;
- RegCount = sizeof(asT3LPB_DDRSetting160MHz)/sizeof(DDR_SET_NODE);
+ RegCount = ARRAY_SIZE(asT3LPB_DDRSetting160MHz);
RegCount -= T3LPB_SKIP_CLOCK_PROGRAM_DUMP_160MHZ;
psDDRSetting += T3LPB_SKIP_CLOCK_PROGRAM_DUMP_160MHZ;
@@ -1181,19 +1181,19 @@ int download_ddr_settings(PMINI_ADAPTER Adapter)
case DDR_80_MHZ:
psDDRSetting = asT3_DDRSetting80MHz;
- RegCount = (sizeof(asT3_DDRSetting80MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3_DDRSetting80MHz);
RegCount-=T3_SKIP_CLOCK_PROGRAM_DUMP_80MHZ ;
psDDRSetting += T3_SKIP_CLOCK_PROGRAM_DUMP_80MHZ;
break;
case DDR_100_MHZ:
psDDRSetting = asT3_DDRSetting100MHz;
- RegCount = (sizeof(asT3_DDRSetting100MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3_DDRSetting100MHz);
RegCount-=T3_SKIP_CLOCK_PROGRAM_DUMP_100MHZ ;
psDDRSetting += T3_SKIP_CLOCK_PROGRAM_DUMP_100MHZ;
break;
case DDR_133_MHZ:
psDDRSetting = asT3_DDRSetting133MHz;
- RegCount = (sizeof(asT3_DDRSetting133MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3_DDRSetting133MHz);
RegCount-=T3_SKIP_CLOCK_PROGRAM_DUMP_133MHZ ;
psDDRSetting += T3_SKIP_CLOCK_PROGRAM_DUMP_133MHZ ;
break;
@@ -1207,20 +1207,20 @@ int download_ddr_settings(PMINI_ADAPTER Adapter)
case DDR_80_MHZ:
psDDRSetting = asT3B_DDRSetting80MHz;
- RegCount = (sizeof(asT3B_DDRSetting80MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3B_DDRSetting80MHz);
RegCount -= T3B_SKIP_CLOCK_PROGRAM_DUMP_80MHZ ;
psDDRSetting += T3B_SKIP_CLOCK_PROGRAM_DUMP_80MHZ;
break;
case DDR_100_MHZ:
psDDRSetting = asT3B_DDRSetting100MHz;
- RegCount = (sizeof(asT3B_DDRSetting100MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3B_DDRSetting100MHz);
RegCount -= T3B_SKIP_CLOCK_PROGRAM_DUMP_100MHZ ;
psDDRSetting += T3B_SKIP_CLOCK_PROGRAM_DUMP_100MHZ;
break;
case DDR_133_MHZ:
psDDRSetting = asT3B_DDRSetting133MHz;
- RegCount = (sizeof(asT3B_DDRSetting133MHz)/sizeof(DDR_SET_NODE));
+ RegCount = ARRAY_SIZE(asT3B_DDRSetting133MHz);
RegCount -= T3B_SKIP_CLOCK_PROGRAM_DUMP_133MHZ ;
psDDRSetting += T3B_SKIP_CLOCK_PROGRAM_DUMP_133MHZ;
break;
diff --git a/drivers/staging/media/as102/as102_usb_drv.c b/drivers/staging/media/as102/as102_usb_drv.c
index 0f6bfe7..36150e5 100644
--- a/drivers/staging/media/as102/as102_usb_drv.c
+++ b/drivers/staging/media/as102/as102_usb_drv.c
@@ -367,7 +367,7 @@ static int as102_usb_probe(struct usb_interface *intf,
ENTER();
/* This should never actually happen */
- if ((sizeof(as102_usb_id_table) / sizeof(struct usb_device_id)) !=
+ if (ARRAY_SIZE(as102_usb_id_table) !=
(sizeof(as102_device_names) / sizeof(const char *))) {
pr_err("Device names table invalid size");
return -EINVAL;
@@ -380,8 +380,7 @@ static int as102_usb_probe(struct usb_interface *intf,
/* Assign the user-friendly device name */
- for (i = 0; i < (sizeof(as102_usb_id_table) /
- sizeof(struct usb_device_id)); i++) {
+ for (i = 0; i < ARRAY_SIZE(as102_usb_id_table); i++) {
if (id == &as102_usb_id_table[i]) {
as102_dev->name = as102_device_names[i];
as102_dev->elna_cfg = as102_elna_cfg[i];
diff --git a/drivers/staging/rtl8192e/rtl8192e/rtl_wx.c b/drivers/staging/rtl8192e/rtl8192e/rtl_wx.c
index 4e93669..778d7ba 100644
--- a/drivers/staging/rtl8192e/rtl8192e/rtl_wx.c
+++ b/drivers/staging/rtl8192e/rtl8192e/rtl_wx.c
@@ -1322,9 +1322,9 @@ static struct iw_statistics *r8192_get_wireless_stats(struct net_device *dev)
struct iw_handler_def r8192_wx_handlers_def = {
.standard = r8192_wx_handlers,
- .num_standard = sizeof(r8192_wx_handlers) / sizeof(iw_handler),
+ .num_standard = ARRAY_SIZE(r8192_wx_handlers),
.private = r8192_private_handler,
- .num_private = sizeof(r8192_private_handler) / sizeof(iw_handler),
+ .num_private = ARRAY_SIZE(r8192_private_handler),
.num_private_args = sizeof(r8192_private_args) /
sizeof(struct iw_priv_args),
.get_wireless_stats = r8192_get_wireless_stats,
diff --git a/drivers/staging/rtl8192e/rtllib_wx.c b/drivers/staging/rtl8192e/rtllib_wx.c
index c27ff7e..e5fe2e8 100644
--- a/drivers/staging/rtl8192e/rtllib_wx.c
+++ b/drivers/staging/rtl8192e/rtllib_wx.c
@@ -88,7 +88,7 @@ static inline char *rtl819x_translate_scan(struct rtllib_device *ieee,
/* Add the protocol name */
iwe.cmd = SIOCGIWNAME;
- for (i = 0; i < (sizeof(rtllib_modes)/sizeof(rtllib_modes[0])); i++) {
+ for (i = 0; i < ARRAY_SIZE(rtllib_modes); i++) {
if (network->mode&(1<<i)) {
sprintf(pname, rtllib_modes[i].mode_string,
rtllib_modes[i].mode_size);
diff --git a/drivers/staging/rtl8192u/r8192U_wx.c b/drivers/staging/rtl8192u/r8192U_wx.c
index f6408f9..981de9b 100644
--- a/drivers/staging/rtl8192u/r8192U_wx.c
+++ b/drivers/staging/rtl8192u/r8192U_wx.c
@@ -1211,9 +1211,9 @@ struct iw_statistics *r8192_get_wireless_stats(struct net_device *dev)
struct iw_handler_def r8192_wx_handlers_def={
.num_private_args = sizeof(r8192_private_args) / sizeof(struct iw_priv_args),
#if WIRELESS_EXT >= 17
diff --git a/drivers/staging/rtl8712/rtl871x_ioctl_linux.c b/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
index ef35bc2..299350c 100644
--- a/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
+++ b/drivers/staging/rtl8712/rtl871x_ioctl_linux.c
@@ -2389,10 +2389,10 @@ static struct iw_statistics *r871x_get_wireless_stats(struct net_device *dev)
struct iw_handler_def r871x_handlers_def = {
.standard = r8711_handlers,
- .num_standard = sizeof(r8711_handlers) / sizeof(iw_handler),
+ .num_standard = ARRAY_SIZE(r8711_handlers),
.private = r8711_private_handler,
.private_args = (struct iw_priv_args *)r8711_private_args,
- .num_private = sizeof(r8711_private_handler) / sizeof(iw_handler),
+ .num_private = ARRAY_SIZE(r8711_private_handler),
.num_private_args = sizeof(r8711_private_args) /
.get_wireless_stats = r871x_get_wireless_stats
diff --git a/drivers/staging/vt6655/wpa.c b/drivers/staging/vt6655/wpa.c
index 61ac46f..0afb9fe 100644
--- a/drivers/staging/vt6655/wpa.c
+++ b/drivers/staging/vt6655/wpa.c
@@ -148,7 +148,7 @@ WPA_ParseRSN (
j = 0;
DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO"wPKCount: %d, sizeof(pBSSList->abyPKType): %zu\n", pRSN->wPKCount, sizeof(pBSSList->abyPKType));
- for(i = 0; (i < pRSN->wPKCount) && (j < sizeof(pBSSList->abyPKType)/sizeof(unsigned char)); i++) {
+ for(i = 0; (i < pRSN->wPKCount) && (j < ARRAY_SIZE(pBSSList->abyPKType)); i++) {
if(pRSN->len >= 12+i*4+4) { //oui1(4)+ver(2)+GKS(4)+PKSCnt(2)+PKS(4*i)
if ( !memcmp(pRSN->PKSList[i].abyOUI, abyOUI00, 4))
pBSSList->abyPKType[j++] = WPA_NONE;
@@ -180,7 +180,7 @@ WPA_ParseRSN (
j = 0;
DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO"wAuthCount: %d, sizeof(pBSSList->abyAuthType): %zu\n",
pIE_RSN_Auth->wAuthCount, sizeof(pBSSList->abyAuthType));
- for(i = 0; (i < pIE_RSN_Auth->wAuthCount) && (j < sizeof(pBSSList->abyAuthType)/sizeof(unsigned char)); i++) {
+ for(i = 0; (i < pIE_RSN_Auth->wAuthCount) && (j < ARRAY_SIZE(pBSSList->abyAuthType)); i++) {
if(pRSN->len >= 14+4+(m+i)*4) { //oui1(4)+ver(2)+GKS(4)+PKSCnt(2)+PKS(4*m)+AKC(2)+AKS(4*i)
if ( !memcmp(pIE_RSN_Auth->AuthKSList[i].abyOUI, abyOUI01, 4))
pBSSList->abyAuthType[j++] = WPA_AUTH_IEEE802_1X;
diff --git a/drivers/staging/vt6656/wpa.c b/drivers/staging/vt6656/wpa.c
index 7dde3d6..b16d4dd 100644
--- a/drivers/staging/vt6656/wpa.c
+++ b/drivers/staging/vt6656/wpa.c
@@ -149,7 +149,7 @@ WPA_ParseRSN(
j = 0;
for (i = 0; (i < pRSN->wPKCount) &&
- (j < sizeof(pBSSList->abyPKType)/sizeof(BYTE)); i++) {
+ (j < ARRAY_SIZE(pBSSList->abyPKType)); i++) {
@@ -182,7 +182,7 @@ WPA_ParseRSN(
for (i = 0; (i < pIE_RSN_Auth->wAuthCount) &&
- (j < sizeof(pBSSList->abyAuthType)/sizeof(BYTE)); i++) {
+ (j < ARRAY_SIZE(pBSSList->abyAuthType)); i++) {
pBSSList->abyAuthType[j++] = WPA_AUTH_IEEE802_1X; |
