6lowpan: fix error checking code
Author: Andrzej Hajda <a.hajda@samsung.com>
Bool variable 'fail' is always non-negative, it indicates an error if it
is true.
The problem has been detected using coccinelle script
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci
Signed-off-by: Andrzej Hajda
Acked-by: Alexander Aring
Signed-off-by: Marcel Holtmann
 net/6lowpan/iphc.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/net/6lowpan/iphc.c b/net/6lowpan/iphc.c
index 8dd8388..06287ac 100644
--- a/net/6lowpan/iphc.c
+++ b/net/6lowpan/iphc.c
@@ -482,7 +482,7 @@ static int lowpan_uncompress_multicast_ctx_daddr(struct sk_buff *skb,
 	ipaddr->s6_addr[0] = 0xFF;
 	fail = lowpan_fetch_skb(skb, &ipaddr->s6_addr[1], 2);
 	fail |= lowpan_fetch_skb(skb, &ipaddr->s6_addr[12], 4);
-	if (fail < 0)
+	if (fail)
 		return -EIO;
 	/* take prefix_len and network prefix from the context */
BtrLinux
Privacy Overview
