3c59x: Use setup_timer()
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Convert a call to init_timer and accompanying intializations of
the timer's data and function fields to a call to setup_timer.
The Coccinelle semantic patch that fixes this problem is
as follows:
expression t,f,d;
-init_timer(&t);
+setup_timer(&t,f,d);
-t.data = d;
-t.function = f;
Signed-off-by: Amitoj Kaur Chawla
Signed-off-by: David S. Miller
 drivers/net/ethernet/3com/3c59x.c | 10 ++--------
 1 file changed, 2 insertions(+), 8 deletions(-)
diff --git a/drivers/net/ethernet/3com/3c59x.c b/drivers/net/ethernet/3com/3c59x.c
index 79e1a02..c377607 100644
--- a/drivers/net/ethernet/3com/3c59x.c
+++ b/drivers/net/ethernet/3com/3c59x.c
@@ -1601,15 +1601,9 @@ vortex_up(struct net_device *dev)
 				dev->name, media_tbl[dev->if_port].name);
-	init_timer(&vp->timer);
+	setup_timer(&vp->timer, vortex_timer, (unsigned long)dev);
 	vp->timer.expires = RUN_AT(media_tbl[dev->if_port].wait);
-	vp->timer.data = (unsigned long)dev;
-	vp->timer.function = vortex_timer;		/* timer handler */
-	add_timer(&vp->timer);
-	init_timer(&vp->rx_oom_timer);
-	vp->rx_oom_timer.data = (unsigned long)dev;
-	vp->rx_oom_timer.function = rx_oom_timer;
+	setup_timer(&vp->rx_oom_timer, rx_oom_timer, (unsigned long)dev);
 	if (vortex_debug > 1)
 		pr_debug("%s: Initial media type %s.\n",
BtrLinux
Privacy Overview
